Desoutter CVIL II Controller Data Transfer to Siemens Serial Interface Modules
luyolo21
Feb 2015
Port Elizabeth
Good day All,
We are using a Desoutter CVIL II Controller for a project.
It is currently connected from the RS232 Port of the Contrroller to a Siemens 1 SI 3964R ASCII(RS-232C) ET200 Card (6ES7138-4DF01-0AB0) with the purpose of retrieving the Torque and Angle Value from the Desouter Controller to the PLC.
Using the Standard ET200s FB's i manage to get the data from the controller but the problem im having is that the data is corrupted and hence unusable.
Is there something wrong im doing? The controller is using ASCII protocol and is sending a STRING of data after each cycle. When i connect the controller to Hyper Terminal i do get the results.
Please find attached the relevant information.
Please do not hesitate to ask if you have question.
Kind Regards
Quick question, I have a Desoutter cvic 2 controller that I was asked to make it mobile. It is currently mounted to a huge station on wheels...
1,003
30
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
32
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
224
Hello, I have a set of three tanks with their own trio of Hardy 6600 series load cells. Two of them have no issues with where they are at and...
146
