Loading a Value Using a Parameter File in FactoryTalk View
MarkNightingale
Sep 2010
In The VAT Shed
740
I would like to know if it is possible to write a value to an internal tag using a parameter file in FactoryTalk View.
Basically what I am trying to achieve is to make certain objects change colour depending on which parameter file I load.
So for example if I press Filler 1, the Filler 1 parameter file will load with the display, and all the associated objects for filler 1 will go red. If I press for Filler 2, the filler 2 parameter file will load with the display and all the associated objects for Filler 2 will go red.
I hope this makes sense.
Mark
Isn't there a value already in the parameter file you can use to determine the product? Then just use some logic in the color animation. If there isn't, you could just create memory tags as needed, set them to retentive, and set the value manually.
I do a lot of color animations if FTView with the animation-color control, and then IF THEN ELSE chains of logic to reduce the selection to however many colors I need.
I have set up an internal tag called Filler_Number. When the Goto screen button is pressed I want to put a number into that internal tag, so if Goto Filler 2 button is pressed it will put a 2 into the Filler_Number tag.
In the parameter file can I just write Filler_Number=2.
Mark
PowerFlex 525-Getting"Data Value Out of Range"when downloading in Drive Tab in 5000 Good Afternoon , I started a thread last week. I am...
4,148
Hello all. As the subject reads, i have a question regarding recipes in WinCC Flexible. I' working on a machine where I have a TP177B operator...
2,021
How can I access the web page that allows me to see and upload the pcl or translation file into my Pl1000E? My Pl1000E doesn’t have an ethernet...
128
Hi guys, I have had some issues with uploading a program from a Micro 850 PLC. This is the first time connecting so I don’t have a file on my...
287
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
167
