How to read Calibration Time remaining from a Hineywell XNX Transmitter using HART
sanger
Nov 2005
Toronto
172
The Honeywell XNX Universal Transmitter describes how to get the number of days remaining until calibration is required using Modbus but I can not find information on how to do thus using the HART protocol.
We are using a ControlLogix with 1756-IF16H HART enabled input modules.
Any ideas.
Navigation to the sensor life variable via HART is 1-3-8-2 as shown in the XNX Universal Transmitter Technical Manual, release 1 March 2009 on
Page A-13 in Appendix A - HART Protocol:
We're looking to read the parameter pragmatically with the 1756-IF16H module rather than via the hand-held terminal.
I believe that HART data that reside outside the primary through 4th variables or data that are not status tags are considered HART pass-through communications.
The AB manual, chapter 8 talks somewhat about pass-through messaging
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1756-um533_-en-p.pdf
1756-um533 manual for 1756-IF8H HART module
There are some passthrough programming examples in this document from Spectrum Controls, an A-B authorized partner who offers HART modules:
(not the same model as the A-B model)
Owner’s Guide 0300196-02 Rev. E
CONTROLLOGIX HART ANALOG MODULES
Catalog Numbers: 1756sc-IF8H, 1756sc-OF8H
http://www.spectrumcontrols.com/pdfs/abio/1756sc_Analog_HART_Manual_0300196-02e.pdf
If it were me, I'd investigate using Modbus RTU (on RS-485), because the sensor life data you want is readily available with a Modbus 03 read holding register command as a floating point value from registers 40009/40010, in units of days.
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
97
Is there a way to use the FAL instruction to do +=2 instead of +=1? I have an array that is organized with alternating "data" and "flag" values...
121
Hi everyone i have a customer, who wants to show an alarm on the machine, if the I/O forces are enabled and set, on at ControlLogix L81E with...
222
Hi Iam using monitouch hmi(V9 soft) with omron plc cj2m (CX programmer). In this I want to read a data from hmi to plc. The data was like...
90
Hi everyone. Quick questions. On UnityPro, I want to open and quickly read tags from a .STA files witouth opening the program. I have 30 plc...
126
