Panelview 1500
Hojland
Oct 2006
Langå
203
Hey guys.
I have recived a new Panelview 1500, because the old one is broken. I have the .apa file but how do i installe the software to the new Panelview. What program do I need. Rsview.....but what version. I have Rslinx and Rslogix500
If it's a Panelview Plus (and i'm guessing it is when you mentioned .apa files) - then you are going to need RSView Studio ME (current version is 4.0).
This uses RSLinx Enterprise (not classic as with your RSLogix).
Once you have the Studio software, open the 'application manager' and use 'Restore' to bring the .apa file into your project list.
There are other things you need to be aware of, but as you don't have the software yet, i would start there...:)
Hope this helps!
Rob
RS Linx Enterprise is included with RS View Machine Edition.
Once you restore your backup. You have to create the runtime file. and download it to the Panel View through transfer utility.
Capriconian
You can actually just double click on the .apa (as long as you have RSView installed) and it will start the restore process.
One thing to keep in mind, if you have user accounts setup, you must check the option "Restore RSView Machine Edition application and FactoryTalk Local Directory". If you don't, it will dump your user account. Or it least it does for me.
24
Hi there, Maybe I am overthinking this issue, but here is what I have going on. I have a program running for a water valve on a DI system. We...
443
Hello, I have 2 PanelView+ 1500s and the touch screen freezes up from time to time. Sometimes it will for a few days then other times it will do...
1,591
Hi guys. Currently working on a project that requires a Panelview Plus 1500 to read a CSV File (recipe) from a network drive. The issue I have...
1,059
Hi, guys, how’s going? I added one “Trend Object” on screen A in PanelView Plus 1500. Then configured “Refresh Rate”, “Buffer” ……and set up...
1,905
