Creating a MSG path string
rootboy
Jan 2004
Tennessee
1,375
Hi guys,
I'm working on a program that changes its MSG path dynamically via a string. It's not my code (customer supplied), and it's not working. :/
The MSG instruction is talking to a Fanuc robot, and is in the format of:
'$01$03$12$p192.168.1.100'
This is the way that it's working elsewhere, so I've got assume that the problem is on my end.
Has anyone set up a MSG instruction this way before, and what do the parameters mean in this context?
Thanks!
I assume this is a Logix:
you need to pad path string to even number of characters, so, it will look like this:
'$01$03$12$r192.168.1.100$00'
where $r represent hex value of 0D =13 characters.
$p = 0C is for 12 characters
There are few TNs in the knowledgebase that explain the path in string format. I think manual does it also.
The easiest way to verify path is to create a dummy message, type a path needed in GUI and verify string format in the MSG.PATH tag
I know the latest Stratix switch Faceplate sample code has AIO that converts text string to the PATH format
Thanks! We had it all correct with the exception of making a null terminated string. So we extended the string length by one, and made sure that the last character was a '$00'.
So close, yet so far... :)
So that's it !
I wrote some code like this on a system where I had 90 near-identical Ethernet nodes, but I couldn't get it to work right for the ones addressed under .10 or over .100.
The even number makes sense now. Thanks !
Wrong!
I guess, you did not read my post completely - you only add $00 if you have an odd number of characters to make it even.
Here is an example: $01$03$12$0E162.168.35.100 - as you see it does not have $00 at the end
Wrong!
No I didn't. :oops: I see the even number reference now. Many thanks!
The idea here is to provide for a brief rapid influx of message codes while preventing sequentially repeating the same message. i.e. if two...
23
661
Hello everyone, In a factory where we installed Citect 7.20 the computer began to show the first signs of end of life. They never considered...
70
Hi everyone, I'm a last year student at the university in Ghent, and for my thesis i need to write a TwinCAT program that writes data to a .daq...
135
When I go to create a new module in Studio 5000 I can't enter any information for the IP Address or change any other fields. Is there any fix to...
249
Hello I am kind of new to the Rockwell world, i've mainly worked with Siemens and Schneider untill now. I am to make a HMI application running...
1,050
