Industrial A/D Converter
Bbarnett
Jul 2013
United States
77
I have an analog signal, 0-10V, that I need to convert to 8 digital bits. What is best way to do this in an industrial setting? Only thing I have found is a Weidmuller RS U-D8 A/D. Anything more common?
Instead of looking for such hardware (0-256 granularity!) just connect said 0-10 VDC signal to any major automation platform Analog Input point then scale the signal's Engineering Units as InputMin = EUMin = 0 and InputMax = EUMax = 256.
If this is not good enough, create a SINT (Short Integer) tag and Move/Copy the scaled values of the Analog Input point into the 8-bit SINT tag.
So, I guess what your'e saying is that the only way of doing this is to buy a PLC with an analog input card / digital output card?
Given that have already found a Weidmuller unit that can do it, it's certainly not the only way, but it is a way to do it. Among the lower cost models is the Automation Direct Click, for which the software to program it is free.
Curious..Then what?
Not the only way...A better way maybe...
I presumed that a 2017 "industrial setting" will contain at least one PLC...The analog feature could be added if not available...
Texas Instruments provides some 'Arduino Class' 8-bit Analog-to-Digital converters (http://www.ti.com/lit/ds/symlink/adc0802-n.pdf), however, this is not what I would consider suitable for a "industrial setting"...:D
I came across this thread because I was asked to do something similar and I was wondering how to price it. But, really, are you serious? The ADC0802 series is not "Arduino class" Those things have been running on industrial instrumentation since the early 80's!
I'm looking for a standalone A/D converter like the one in the link but with 16-bit accuracy rather than 8-bit. Know of any product...
5,729
Hello, I am looking for a solution to remotely access any kind of device securely across the internet. I know this has been done in piecemeal...
22
2,196
Hey Everybody, I resigned from teaching, to pursue an IT career, and my original objective was to prepare for and pass a few entry level certs...
570
I'm working on an application and have hit a bit of a snag. I need to find an industrial touchscreen display that can: - Tolerate down to -40C...
749
I swear I post this yesterday but can't find it. Don't see any notification about the post removal either. Maybe my memory is malfunctioning...
2,550
