Issues connecting with an Energy meter through MODBUS
keristos
Aug 2011
Malta
65
Hi guys, here's a little description of the issues I'm having.
This is not the first time I am using MODBUS to connect with devices, I do it very often. Any help would be appreciated!
I am trying to connect to a BTcino F41TMA energy meter through MODBUS. After various failed attempts to connect using a PLC I tried to connect the energy meter to a USB to RS485 converter directly with my Laptop. This allows me to manually send messages to any MODBUS device.
I input the parameters in the software to match those set on the device and started transmitting;
Address: 7
Baud Rate: 9600
Parity: None
Register Address: 4097
Function: 3
The result I got was [00], an ‘illegal response’.
I changed the Register address multiple times using: 96, 4096, 97, 4097, 100, 4100.
I also changed the Baud Rate on both the device and my laptop from 9600 to 19200.
The Function was also changed between 3 and 4.
Switching the Modbus wires or disconnecting the Modbus cable completely results in a ‘time-out’ and hence this led me to believe that the connection is in fact correct but the device seems to be returning an illegal response.
This link leads to screenshots of the software.
This link is for the MODBUS Table of the device.
Thank you,
Patrick
Address: 7
Baud Rate: 9600
Parity: None
Function: 3
Thank you,
Patrick
Don't know the slave but is it defined that the registers are input registers ?
Try the data type as holding registers.......
Actually, ignore that, just re-read your post.
The Modbus map for the addresses 4096 through 4180 shows a length of 2, while the power factor at address 4182 shows a length of 1 even though both are listed as unsigned integers. When you were trying to read address 4096, did you use the correct length? It should have been 2 words.
Yes I tried changing the length, it should work nonetheless, it just wouldn't make sense as a value. I believe reading 1 or 2 or 5 registers doesn't make a difference as long as the registers exist. Correct me if I'm wrong.
Thank you
I agree, the length should not matter as long as the registers exist. However, the slave may have rejected the request if you asked for one word of data when the variable you're trying to read is two words. Because Modbus is non-proprietary, there is wide variation in how different users implement it.
I also wonder if that one-character ([00] hex) response shown in your Modbus tester screenshot actually came from the slave. If the slave did not accept the command from the master, the normal exception code would be to echo the command code with the MSB set. In your case the exception response to the [03] hex command would be [83] hex.
I did try with different lengths and I kept getting the same response.
Do you think the modbus could be blocked on the devices? And maybe the [00] response is some kind of a 'bad password' or 'no access'?
I googled that model number and the only datasheet I found indicated that it uses RS485 for serial communications. Did you terminate the RS485 cable at both ends? What are you using for a converter between your computer and the RS485 cable? Could that device be responsible for the [00] response?
To be honest, no, I didn't terminate one either end. It's not something I usually do and I never had issues even with long runs of cable.
I can't tell you the device I used at the moment since I'm not at the office, but it was a prolific USB to RS485 converter.
With regards to the response being from the converter, I don't believe it is. I say this because upon disconnection of the cable from the energy meter's end I get a 'timeout' error.
Thank you for your help so far
Is there further documentation in English? You might experiment with the 'data bits' setting (though with No Parity 8 data bits is almost mandatory). Maybe the number of stop bits?
looking at your data screenshot, none of those commands are addressing what you require.
I suspect the red 00s are a nul at the end of the message so these can be ignored. There is no response from the slave at all in that data you have sent.
I could be wrong, but I don't think there is a such a thing as an exception response of 00?!
So what you have is:
07 04 1000 0001 356C
The 07 is your node address = correct
the 04 is your modbus code. 04 is for input registers. The modbus table you have posted shows that they are HOLDING registers so need the modbus read code 03. See the column on the far right.
the 1000 is your 4096 address
the 0001 is the length = seeing as register 4096 is a length of 2, I would change this for 2. If you are trying to troubleshoot something which isn't working there is no point inducing problems!
356C is the checksum.
So the message you need to see from your modbus simulator is...
07 03 1000 0002 356C
Try changing from reading input registers to holding registers.
Thank you for your reply. In my OP I mentioned that I tried every combination possible, including using function 03 instead of 04, different register lengths, different baud rates and even different register addresses.
Unfortunately I don't believe this is the problem :(
I will try nonetheless, the next time I have an on site visit, the exact settings you suggested.
I'm worried that Modbus might be disabled and I require some special password to access it / enable it.
Thank you
I think you need to look at cabling and comms setup in the slave and double check, I don't think you are connected to the slave at all, one your screenshots of Modbus Poll states that ?
Is it a 2 wire or 4 wire device, which USB > RS485 converter are you using, has it got Rx and Tx lights, when you send a request you should get an Rx at the laptop end even ifs its an illegal response as the slave will be Tx'ing that back to the master
Also just one quick one to check is the base of the addressing very often this can make your addressing offset by 1 resulting in Illegal Data Read
Yes I tried both addresses 4096,4097 (due to that offset by on that some devices seem to have)
Hello all, hope your week is going well. I am currently working on debugging a Micro850 with Category number 2080-LC50-24QWB. When I connect...
2,335
I'm trying to resurrect an older machine from around 2005 that uses a 140CPU43412A. The goal is to retrieve the existing program so that it can be...
3,400
I am having some issue connecting to the Factory Talk Server. We Have been running an application on FactroyTalk View Studio for about 6 months...
7,699
I am trying to connect my 7" Omron NB7W-TW00B HMI to my AB CompactLogix L-31 PLC. Right now I am just trying to pass a single value from my PLC...
3,910
Hi, I am having trouble connecting to a Siemens S7-200 PLC in Citect. - Citect Version: 6.1 SPB, - Driver: SIMPPI 1.00.03.001 - Siemens...
2,685
