PLC/DCS DO card external power supply to field devices
akbarchaghal
Nov 2015
Calgary
I have encountered a problem with PLC and DCS I/O card power supply requirement for field wiring. Do PLC and DCS card both need external power supply to feed the relays or field devies?
I have the case that M-series DeltaV DO card need this power supply but on the other case Tricon 3625 does not need external power supply.
I appreciate if anyone give me some clarification on the wiring to field instruments from DO card.
Thnaks,
Hi Everyone, I am currently trying to communicate ControlLogix PLCs via EtherNet/IP with Delta V DCS. There is a VIM2 card configured for...
275
Hi everyone, I'm working with a company that is developing software that will be used to access and process sensor data from different process...
1,893
Trying to set up a Logix 5000 L73 controller so the customer's Ovation DCS can read some analog and digital values at specific addresses. I think...
1,165
Dear all, Can any one share the procedure how to configure Allenbradley PLC as modbus TCP server with DCS through Prosoft PLX31 EIP MBTCP
2,160
