plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 14th, 2020, 09:49 AM   #1
BachPhi
United States
BachPhi is offline
AOI within an AOI
I came across an AOI that contain another AOI within. Just so 'interesting', IMHO, if you know what I meant.
Just wonder if you have seen them or your pro and con thoughts.
What's next? an AOI within AOI within an AOI?
Old February 14th, 2020, 10:05 AM   #2
mylespetro
Supporting Member
Canada
mylespetro is offline
mylespetro's Avatar
Quote:
Don't let your dreams be dreams, you can achieve anything!
Old February 14th, 2020, 10:59 AM   #3
MarkNightingale
United Kingdom
MarkNightingale is offline
I went to a plant, where I think the main programmer had just learnt about AOI's.
They were 5 deep.
It was such a pain in the a$$.
Old February 14th, 2020, 11:13 AM   #4
DBLD99
United States
DBLD99 is offline
Rockwells own PlantPAX AOIs have AOIs inside of AOIs - It does make sense for certain things.
Old February 14th, 2020, 11:44 AM   #5
mk42
United States
mk42 is offline
In most programming environments, that's very common. The number of levels deep you go is often called the "nesting depth".
Old February 14th, 2020, 12:13 PM   #6
Aabeck
United States
Aabeck is offline
Aabeck's Avatar
Same as JRS's in a program or GOSUB's in a computer program.
Just keep going deeper until no-one can possibly find out what you are doing, what you were thinking, or be able to do anything to your program.
__________________
Never underestimate the quality of idiots that will be running your machines
http://aabeck.com
Old February 14th, 2020, 01:38 PM   #7
bernie_carlton
United States
bernie_carlton is offline
bernie_carlton's Avatar
Ladder logic Inception!
__________________
Controlling outputs is the PLC's way of getting its inputs to change.
www.thePLCguy.com
Old February 14th, 2020, 02:30 PM   #8
Phrog30
United States
Phrog30 is offline
Quote:
Yep.
It's very common and not usual in the least.
Old February 14th, 2020, 03:35 PM   #9
jstolaruk
United States
jstolaruk is offline
Quote:
They were 5 deep.
yeah, more than 2 nested gets hairy. Sounds like a kid with a new toy.
__________________
"You can live to be a hundred if you give up all the things that make you want to live to be a hundred." Woody Allen
Old February 14th, 2020, 04:13 PM   #10
PLCplease
United States
PLCplease is offline
I use a timer to start a timer when I'm timing certain times.
Old February 15th, 2020, 06:40 PM   #11
Geospark
Ireland
Geospark is offline
Geospark's Avatar
Rockwell used to say that AOI instructions may be nested up to 16 levels deep, but recommended limiting the level of nesting to eight levels to reduce complexity and make the instruction easier to manage.
Quite sensible, we would agree?...
They then tore up that book of sense at Studio 5000 v27, and "changed" AOI nesting to a maximum of 25 levels, no less.
But just remember kids, play careful now and try not to fall down the rabbit hole.
Regards,
George
__________________
"A little nonsense now and then is relished by the wisest men".
Old February 16th, 2020, 05:18 AM   #12
drbitboy
United States
drbitboy is offline
Quote:
I dunno if that sounds like a good idea in the real-world, cause-mayhem realm of PLCs, but in the non-real world of procedural languages I am comfortable having an AOI-equivalent call itself to an arbitrary nested depth; that capability is one of the many things that makes these silly computers so durn useful.
I heard that in the dictionary, the definition of recursion says "See recursion"
Old February 16th, 2020, 06:30 AM   #13
jstolaruk
United States
As cool as it is, recursion is caught by the compiler and not allowed in Studio/RSlogix 5K when it comes to AOIs or UDTs. A JSR call to "itself" is allowed but I haven't tried it without a way to "break" the call cycle. I would expect no less that a major fault.
__________________
Old February 16th, 2020, 06:53 AM   #14
drbitboy
United States
drbitboy is offline
Quote:
Fortran has the same restriction, or at least one of the many incarnations I used once did. However, you could call subroutine A, then have A call subroutine B, and B could call A; let's call it recursion by proxy.
Such a scheme would limit the recursion depth to half the nesting limit, but would the rsl5k compiler catch it as recursion?
If there ever was an actual useful purpose for this (e.g. a FIFO of structures instead of bits), then obviously there would need to be a way to limit the recursion depth, but that is not difficult.
Not exactly on-topic, please excuse the distraction.
Old February 16th, 2020, 08:58 AM   #15
BachPhi
United States
BachPhi is offline
Keep in mind there are certain instructions not available within AOI. So you are forced to make a 'SMALL' AOI within an AOI. Case in point BitShiftX . Here I am referring to a big/complex AOI within an big, complex AOI.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Setting up a MSG in an AOI pierrer LIVE PLC Questions And Answers 7 November 22nd, 2018 04:37 PM
Manipulating Strings in RSLogix 5000 aoi written in ladder Eoghan LIVE PLC Questions And Answers 5 October 17th, 2018 03:17 PM
Programming Exercise: Sorting Algorithm w/Dynamic AOI Results Paully's5.0 LIVE PLC Questions And Answers 19 January 29th, 2017 05:32 PM
AB AOI design Inputs, Outputs, or InOuts? abishur LIVE PLC Questions And Answers 5 November 16th, 2016 09:55 AM
Add stringtext to multiple AOI local tags. shauntieu LIVE PLC Questions And Answers 1 November 1st, 2011 09:21 PM
