plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 6th, 2016, 05:49 AM   #1
SautauxT
Switzerland
SautauxT is offline
Create/Read File in Twincat 2
Hi!
First at all, I don't speak English very well so sorry for the faults
I'm new in the Twincat environnement and I have to do a little project for Philipp Morris during my studies.
I have a problem with a little sub-program that I've made.
I have to do a system who can measure the length of cigarettes and save all the results in the PLC's memory. For the program who saves the results, I tried to do like the Beckhoff example here:
https://infosys.beckhoff.com/english...leopen.htm&id=
The one from Beckhoff is a simple function block that copy some stuff, it works step by step with on Case OF,
I tried to do like this one but with two Case Of because I have one button who saves the results, and another one who can open the olds results
But it doesn't work well. The problem are:
- I can't open the files
- When I save something, the FB_FileOpen stay busy and I'm stuck in the step 2 of my case of
So here's the program who saves the results, tell me if you see some errors or if something is missing:
Variable
PROGRAM
Gestion_Fichier
VAR
Save_Array: BOOL:=FALSE; (*Trigger for saving*)
RTRIG_Save_Array: R_TRIG;
FileNameSave: STRING:='Batch'; (*Name of the new file*)
BatchID: STRING:='B00000';
hSavedFile: UINT;
Step_Save: INT:=0;
Open_Array: BOOL:=FALSE; (*Trigger for the opening of an old array*)
RTRIG_Open_Array: R_TRIG;
FileNameOpen: STRING:='Batch'; (*Name of the old file you want to open*)
BatchID_ToOpen: STRING:='B00000';
hOpenedFile: UINT;
Array_Opened: ARRAY [1..100] OF LREAL:=100(0); (*It's the target where I want the old opened array*)
Step_Open: INT:=0;
FB_FileOpen1: FB_FileOpen;
FB_FileWrite1: FB_FileWrite;
FB_FileClose1: FB_FileClose;
FB_FileOpen2: FB_FileOpen;
FB_FileRead2: FB_FileRead;
FB_FileClose2: FB_FileClose;
T_AmsNetId: T_AmsNetId:='5.24.113.50.1.1';
END_VAR
Programme
FileNameSave:= CONCAT('\Hard Disk\MesurePlug\', BatchID);
FileNameOpen:= CONCAT('\Hard Disk\MesurePlug\', BatchID_ToOpen);
RTRIG_Save_Array(CLK:=Save_Array);
RTRIG_Open_Array(CLK:=Open_Array);
CASE Step_Save OF
0:
IF RTRIG_Save_Array.Q THEN
FB_FileOpen1.bExecute:=FALSE;
FB_FileWrite1.bExecute:=FALSE;
FB_FileClose1.bExecute:=FALSE;
Step_Save := 1;
END_IF;
1:
FB_FileOpen1(
sNetId:= T_AmsNetId,
sPathName:= FileNameSave,
nMode:= FOPEN_MODEWRITE OR FOPEN_MODEPLUS,
ePath:= PATH_GENERIC,
bExecute:= TRUE,
tTimeout:= ,
bBusy=> ,
bError=> ,
nErrId=> ,
hFile=> hSavedFile);
Step_Save:=2;
2:
IF NOT(FB_FileOpen1.bBusy) THEN
FB_FileWrite1(
hFile:= hSavedFile,
pWriteBuff:= ADR(Mode_Auto.Arr_Temp),
cbWriteLen:= SIZEOF(Array_Opened),
bExecute:= TRUE,
tTimeout:= ,
bBusy=> ,
bError=> ,
nErrId=> ,
cbWrite=> );
Step_Save:=3;
END_IF;
3:
IF NOT(FB_FileWrite1.bBusy) THEN
FB_FileClose1(
hFile:= hSavedFile,
bExecute:= TRUE,
tTimeout:= ,
bBusy=> ,
bError=> ,
nErrId=> );
Step_Save:=0;
END_IF;
END_CASE;
(*Lecture fichier*)
CASE Step_Open OF
0:
FB_FileOpen2.bExecute:=FALSE;
FB_FileRead2.bExecute:=FALSE;
FB_FileClose2.bExecute:=FALSE;
IF RTRIG_Open_Array.Q THEN
Step_Open := 1;
END_IF;
1:
FB_FileOpen2(
sPathName:= FileNameOpen,
nMode:= FOPEN_MODEREAD OR FOPEN_MODEPLUS,
bExecute:= TRUE,
tTimeout:= ,
bBusy=> ,
bError=> ,
nErrId=> ,
hFile=> hOpenedFile);
Step_Open:=2;
2:
IF NOT(FB_FileOpen2.bBusy) THEN
FB_FileRead2(
hFile:= hOpenedFile,
pReadBuff:= ADR(Array_Opened),
cbReadLen:= SIZEOF(Array_Opened),
bExecute:= TRUE,
tTimeout:= ,
bBusy=> ,
bError=> ,
nErrId=> ,
cbRead=> ,
bEOF=> );
Step_Open:=3;
END_IF;
3:
IF NOT(FB_FileRead2.bBusy) THEN
FB_FileClose2(
bExecute:= TRUE,
tTimeout:= ,
bBusy=> ,
bError=> ,
nErrId=> );
Step_Open:=0;
END_IF;
END_CASE;
Thank you if you can help me
Old September 6th, 2016, 05:54 AM   #2
SautauxT
Switzerland
SautauxT is offline
Ho and I forgot to say something..
this is the PLC: CP6201-0001-0020
Old September 6th, 2016, 08:27 AM   #3
Iman
Iran
Iman is offline
Iman's Avatar
Attach your logic (PRO)file. it is better for diagnosis
Old September 6th, 2016, 09:05 AM   #4
SautauxT
Switzerland
SautauxT is offline
Yep of course, there it is
Old September 12th, 2016, 07:09 AM   #5
Berke84
Belgium
Berke84 is offline
Hi SautauxT,
Sorry, I didn't have the time to fully evaluate your PLC code but I do have a sample for this with a User Manual included. I've added it in a attachment
Good luck with it & best regards!
Bert
Old September 12th, 2016, 11:00 AM   #6
SautauxT
Switzerland
SautauxT is offline
Hi!
I just found finally a solution to my problem but I'll have a look at your function Block, maybe it will work better with it.
Thank for all,
Best regards!
Thierry Sautaux
Old September 15th, 2016, 01:39 PM   #7
ElGranMaikel
Spain
ElGranMaikel is offline
Hi Thierry,
I am working with twincat 2 and I have the same problem as you, fb_fileopen just doesn't give me hFile. Would you mind telling me how did you solve the issue?
Thanks in advance,
Best regards,
Mikel Losada
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Codesys :How do i read all lines of text from a text file? EnterDownload LIVE PLC Questions And Answers 1 September 1st, 2015 02:11 PM
Factory Talk View Studio ME older .mer that doesnt allow conversion jtashaffer LIVE PLC Questions And Answers 13 April 25th, 2015 06:58 AM
RSLogix 500 Installation nagaraj_h LIVE PLC Questions And Answers 13 December 18th, 2014 08:11 PM
How to switch drivers lbeh LIVE PLC Questions And Answers 7 December 11th, 2014 03:11 PM
am i correct? excel & logix CSV communication. fusion LIVE PLC Questions And Answers 14 October 19th, 2005 07:18 PM
