plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 13th, 2020, 05:24 PM   #1
PLCplease
United States
PLCplease is offline
Question I have to head to a customer tomorrow and upload from MicroLogix 1000
What am I going to get? A program with rungs and instructions and absolutely no descriptions and comments?
There is no offline version of the program available. We are upgrading them to Compact Logix, I was just hoping I had a program to work with to reconstruct the logic.
I've never worked with anything prior to Micro 1400.
Any tips? Thanks for any insight.
Old February 13th, 2020, 05:26 PM   #2
the_msp
United Kingdom
the_msp is offline
the_msp's Avatar
Correct. Without a digital copy of the program, you won't get the comments.
You might be in luck and find a printed copy somewhere on site.
__________________
Regards,
Patrick
Connect with Matrix Engineering on Facebook
Old February 13th, 2020, 05:34 PM   #3
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
On the bright side, the ML1000 only has 1K of memory, no floating point, no expansion I/O and many other limitations, so the amount of documentation you have to rebuild should be minimal. Look for electrical drawings while on site and take a lot of pictures.
__________________
You can choose a ready guide in some celestial voice. If you choose not to decide you still have made a choice.
Old February 13th, 2020, 05:43 PM   #4
diat150
United States
diat150 is offline
yeah worst case you trace out the IO, on a micrologix 1000 that should give you a good head start.
Old February 13th, 2020, 05:45 PM   #5
kolyur
United States
kolyur is offline
kolyur's Avatar
We deal with this a lot when we have to work on purchased equipment where the OEM was not willing to provide a documented program. After uploading the logic, I usually go through and name all the inputs and outputs; this is easy if you have a schematic and just a bit more work if you don't. At that point you can usually make sense of an average sized program as long as the programmer didn't go nuts with his internal memory bits.
__________________
John
Old February 13th, 2020, 05:49 PM   #6
PLCplease
United States
That's what i was afraid of. Thanks guys
Old February 13th, 2020, 05:57 PM   #7
the_msp
United Kingdom
the_msp is offline
the_msp's Avatar
Note also there may be a password on the program so you might not even get that (easily anyway).
__________________
Regards,
Patrick
Old February 13th, 2020, 06:03 PM   #8
ASF
Australia
ASF is offline
If you have to reverse engineer it, spend at least a day onsite, online with the PLC, while the machine is running. Start by entering descriptions for all of the I/O, and then start commenting the memory bits based on the I/O comments and what you can observe of the machine operation and code activity. It's a bit like a crossword - it's tricky to start with, but the more pieces you fill in, the more clues you get to help you out with the rest of the unknowns.
I recently had to do this with a very large micrologix 1500 PLC, that had only very minimal (and mostly incorrect/misleading) documentation. Took a while, but like I say, you plod away slowly for a while and eventually hit a tipping point where you've documented enough that the remaining bits are easily worked out.
Old February 13th, 2020, 07:29 PM   #9
jstolaruk
United States
jstolaruk is offline
Its a right-of-passage for plc programming.
__________________
"You can live to be a hundred if you give up all the things that make you want to live to be a hundred." Woody Allen
Old February 14th, 2020, 02:50 PM   #10
PLCplease
United States
Well, that went waay better than expected.
There were only 9 inputs, all prox's, and only 4 outputs.
The program looks ridiculous, though.
Raggedy old machine.
https://imgur.com/a/7FKxEs0
Old February 14th, 2020, 04:06 PM   #11
kolyur
United States
kolyur is offline
kolyur's Avatar
The OSHA inspector must have called in sick that day.
__________________
John
Old February 14th, 2020, 05:25 PM   #12
shawn_75
United States
shawn_75 is offline
I had to look up poka yoke. What throws a poka yoke error in that machine?
Old February 14th, 2020, 06:43 PM   #13
geniusintraining
United States
geniusintraining is offline
geniusintraining's Avatar
Quote:
I am guessing... but when the lamp blows up and blows off the green cover the lamp, thats an error
__________________
www.PLCCable.com PLC Communication Cables, PLC Trainers, MicroLogix, ControlLogix, Siemens, Allen Bradley and more...OEM and aftermarket supplies... Aftermarket 1784-U2DHP Allen Bradley USB to DH+, new USB to 485 modbus
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
