Omron Relays
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Has anyone seen relay blocks like this (G6B-4CB)? I am retrofitting an old machine with new drives and it appears to me that the two blocks on the left aren't being used....since I don't see but 0V wires terminated at the bottoms of these. They run from this relay to an I/O connection board (also Omron), that then connects to the I/O port of an MC421. Thanks
Haven't used it but it seems pretty straightforward looking at the datasheet. One thing to be aware of, it appears that the positive sides of all the coils are jumpered internally. This means the signals activating the individual coils would need to be negative/0V, i.e. from a sinking output module.
EDIT: To address your original question, it does look like the N.C. contacts on the left two relays are in use (9-5 and 10-6).
Nice! May I ask where you found this? I looked all over. I found other relay blocks but not this one in specific. I also have a G6B-4BND, which I did find the datasheet for.
The G6B-4B and G6B-4C are quite a bit different
For awhile we've been using the Omron G7SA force guided relays in our safety systems. Recently we switched from the screw connection socket to the...
1,308
My question is as follows I have to install an 8-point relay at work and I am not too familiar with control work. The purpose for this relay is...
2,389
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
40
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
53
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
230
