Is it possible to connect a PC directly to a SLC 500 5/02 CPU?
AratanAenor
Jul 2020
Maine
I recently inherited some 5/04 CPUs and a single 5/02 CPU that I need to pull the programs from. The 5/04 CPUs didn't pose any problems. I simply connected directly to the RS232 port on the 5/04 from the RS232 port on my laptop and used the RSLinx DF-1/DH-485 driver.
The 5/02 gives me pause, since it only has an RJ45 port for DH-485. I was wondering if it's possible to connect my laptop directly to the 5/02 using a modular RS232 to RJ45 adapter and the RSLinx DH-485 driver. I don't want to buy a 1747-PIC adapter for a one-time use if I don't have to.
no to be "that guy" but usually if you have a decent relationship with your local distributor they usually can lend out something like that for a day for free
Welcome to the forum.
I agree with 0949er, if you explain to them that you need the program out of the plc so you can look at the logic for an upgrade to a new system, that will really help (assuming that is what you are doing)
james
Welcome to the PLCTalk forum community !
The only practical way to get the program out of an SLC-5/02 is to use a 1747-UIC.
The time spent preparing a suitable computer (XPSP2 or SP3 or earlier, carefully patched and connected to a motherboard-native UART) to use a 1747-PIC or 1761-NET-AIC will exceed the cost of a 1747-UIC. The only "clone" anyone endorses is from PLCCABLES.com.
When I was an RA local rep, I loaned tools and helped with this sort of thing in my office all the time. All I asked for in return was the opportunity to review one system or subsystem for upgrade.
Along with seeing if you can borrow a UIC maybe you can take the 5/02 to them and they can pull the program and put it on your flash drive with the CPU in a bench rack.
Or see if any other local shop has a UIC that call pull it for you.
But, with so many SLC's out there I would suggest getting a UIC - even the 5/03's, /04's and /05's DB-9 port can be configured to DH485 (that needs the UIC) often setup for a Panelview.
I do want to answer this question directly:
[is it] possible to connect my laptop directly to the 5/02 using a modular RS232 to RJ45 adapter and the RSLinx DH-485 driver.
It is not.
The sole network port on an SLC-5/02 controller is Data Highway 485, which as the name suggests, uses RS-485 3-wire signalling. To connect to it from a computer, you need a device with an RS-485 transceiver, not an RS-232 transceiver.
Those include the classic 1747-PIC with its ribbon cable and 25-pin RS-232 connector, and the 1761-NET-AIC "AIC+", as well as the modern 1747-UIC USB to DH485 interface.
Also, the network port on an SLC-5/02 has +24V on Pins 3 and 8, so you can easily damage devices by connecting those pins to a non-DH485 device.
The DH485 protocol can run on a network link that has RS-232 on both sides. But that doesn't apply to an SLC-5/02 CPU.
Thank you for the suggestions and information. I will look into purchasing a 1747-UIC. I don't see SLC 500s often, but occasionally (like now) we acquire an older plant that has them. So it probably wouldn't hurt to have a UIC in my cable drawer.
+1 for the unit offered by Geniusintraning. I have used that unit myself and it works great with windows 10. At that price it is worth it to have one on hand.
Not AB, but years back I made the equivalent of a Mitsubishi SC-09.
I had to use a RS-232 - Reverse RS-485 converter, (for 2 channels) with separate AC adapter, then make a custom cable for the PLC side. A SC-09 turns out would have cost less and a lot less work finding pinouts and making the cable.
A standard RS485 converter might work for a DB-9 port set to DH485, but the SLC5/02 in the OP only has the RJ45 connector and he would have to make a custom cable to use it, plus the external AC adapter (and if I remember its own extension cord because no outlet was ever close enough).
Excuse my ignorance, would perhaps some of these work?
https://www.mouser.com/Search/Refine...240+4292906361
Or does DH485 not ride on top of standard RS-485?
From what I understand Data Highway 485 (DH485) is not the same as RS-485 and you cant just use a USB to 485 converter to make things work. You have to remember who you are dealing with here, Rockwell. Nothing is easy or cheap 🍺
"Why can't this random RS-485 device work with Data Highway 485" is just the English translation of "Warum funktioniert dieses gerät RS-485 nicht mit Profibus DP?"
Data Highway 485 really does use ordinary RS-485 transceivers. They're referenced to a common wire that is isolated from the rest of the circuitry, which gives nodes good immunity to ground loops and induced noise.
But it's a token-passing protocol with fairly tight timing requirements. It's not asynchronous, like DF1 or Modbus or ASCII, or packet-based like TCP/IP.
General-purpose devices that convert from USB or some other protocol or standard to RS-485 don't necessarily know when to switch from transmit to receive. Even on modern computers, a comms driver located several layers of electronics and operating system and application from the device can't get the timing right.
I spent a LOT of time in the late 1990's trying to get USB devices to work with DH485 and Windows. It was all wasted effort. Even the Indian-made hardware that eventually became the 1747-UIC wouldn't work until engineers in Cleveland made it work.
LOL.
thanks for answering my query.
The interesting thing is that the -UIC device connects a serial comm port (rs-232 or rs-485), so I suspect there are some extra smarts in the pay-extra-for cable.
The 1747-UIC uses a microcontroller that runs the DH-485 token-passing protocol on one serial port, and implements a DF1 Full Duplex driver over a USB serial port on another.
Because DF1 is asychronous, it runs fine over a modern Windows USB serial port.
On versions of RSLinx Classic from before there was a 1747-UIC driver, you could set up a DF1 driver with the 1770-KF3 device type and it would run the 1747-UIC just fine.
Hi, I have AB Micro820 PLC (2080-LC20-20QBB) which, acc. to the specs, can be both Ethernet/IP master and slave. I need it to be a master and...
2,219
Hello Guys, can you give me a tip? I am designing a Filter Press Station and I can't afford to buy HMI panels so I am going to use my PC as HMI...
2,070
Hi Gents, this is a tricky one. I am waiting to receive an actual Modicon M340 PLC, but I would like to test my code. Is it possible to connect...
5,167
I was wondering in you could gain access of a plc that is connected by dial-up modem on one end and me through the internet on the other ..is...
2,431
Hi i am new one in simens hmi & drives. I am using CPU313-2DP . I have to connect simens HMI(MP277) & SIMENS DRIVES at same time. how should i...
3,361
