GE Series One - Procedure for loading code from cassette tape?
defcon.klaxon
Feb 2015
Far NorCal
616
Hi guys, I have a client that has a GE Series One PLC that apparently needs the code re-loaded onto it; they mention that when they lose power, they sometimes need to reload the code onto the PLC.
The code is stored on a cassette tape, and they use a portable stereo to play it. They say they have a procedure for doing this, but they can't find it. Wondering if anyone has worked on these systems, and if you could provide some help for a procedure?
This is exactly what ours did. It started off as every blue moon,it would dump the program. It then escalated quickly to the point that it will no longer accept a program.
Better get the little display out and go through the program and write it down so you can upgrade later on. I’ll be replacing ours next week.
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
36
257
Hi, We couldn’t find anything specific, so am starting a new thread. I’m trying to migrate a config from a ML1400 to a micro820 & am experiencing...
92
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
98
