I want to try and use a Ethernet device in my RSlogix 5000 program. As far as I know, no-one has ever used it with a PLC.
The device is a programmable serial to Ethernet converter and has a configurable ip address with software that can be used to change settings and such. It would generally be used in a PC but I'm trying to give it a shot with a PLC.
I've worked with Ethernet/IP modules before, the only thing is that this module/device has 5 ports in (serial) and 1 ethernet port out. I need to be able to read data from each serial device separately. The device it self has pre-assigned port numbers so I can call to receive information from any of the 5 ports.
Normally I would just use a comtrl DeviceMaster or RedLion product, but I'm trying out something different.
Has anyone done something similar?
