Why Can't I drag Done bits or timer timing bits in RSLogix 500?
just a guess ... in your screenshot you've highlighted (blue) the entire timer ... try highlighting just the Done bit/box instead ...
Operator Error!
Hi Ron,
That was it.
When I selected the timer the whole row was highlighting.
It works correctly when I operate the program how it is supposed to work.
I wish RSLogix 500 would let you drag the EN or DN bit from the instruction block in the ladder view to a bit instruction...one of those details that would be nice to fix.
This is actually what I thought the thread was going to be about. Just let me drag the DN bit, it's right there!
And it is usually on the rung right above where you intend to drop it...There are a couple of other minor things like that I wish for...Then I have to use Directsoft 6 for a day, and that puts an end to my gritching about the RSLogix editor.
Hi, do you know how i can add pens in a trend by drag and drop the variables, without using "Add/configuring tags" windows. The Add/configuring...
1,132
Hello Guys, Im having trouble to drag and drop symbols that i imported into symbol factory in factorytalk view? does anybody know why? the format...
1,837
Good evening, I can't drag the rung down around my inputs and outputs for some reason in my PLC program? I can't do it for any programs. I'll...
1,416
Is it possible to use two infrared sensors . One for starting timer and one for stoping timer. result could go on lcd display or sreen. Could...
1,003
Hi, I have an RSView32 project which includes graphics that show the positions of drilling rigs (displayed as coloured boxes with text on a map...
2,024
