Cannot delete function block from Proficy Machine Edition 8.6
defcon.klaxon
Feb 2015
Far NorCal
616
Hi all,
I have a project that is giving me some issues. I was experimenting with using the TOTALIZE function block in a project, and it never worked so I made my own block; I cannot find any instance of TOTALIZE being used anywhere in my code. Despite that, I cannot seem to delete the block from my Program Blocks. I've tried online and office, with the PLC as active target and not, but no avail. I can't validate the code because I get an error saying "Error 12531: Function Block 'TOTALIZE' is not licensed for use on this system". In Companion it says that you can get around this error by deleting the function block from the project, but it's literally not letting me. Any ideas for how I can get unstuck? Thanks!
Finally figured it out. Apparently some function blocks require a register and the data type will be that function block. So I went into the Variables list, sorted by function block, and found several "TOTALIZE" variables that weren't being used, but were still in the project. Deleting those then allowed me to delete the TOTALIZE block from the project. God, that was annoying.
Thanks for the help!
Hi Guys, Has anyone experienced errors while attempting to delete an Add on instruction in RSLogix 5000 V16.00? I have removed all logic...
61
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
128
Hello Friends I have a backup that I am trying t open in mi PC (RSLogix 17.01) and I get this message. I have read many posts and done many...
167
Hi, Im trying to open an old old Siemens WinCC project. It doesnt have to run i just want to look at the project in WinCC explorer. Its...
666
Hello. I cannot change the SendClock settings for a PROFINET IO device. I need to slow down the CODESYS PROFINET IO controller. What am I doing...
198
