panelview plus 1000 with keypad. no config at boot
myke2480
Oct 2017
ohio
im having trouble with a pv plus 1000 touch with keypad. cant access config screen. no white square, F1 doesnt work, left and right direction buttons dont work, USB keyboard ctrl-shift-alt-windows buttons dont work. i am just trying to upload .mer file.
See tech note 119811: https://rockwellautomation.custhelp.com/app/answers/detail/a_id/119811
Supposedly there is a way to bring the white square back: https://theautomationblog.com/how-do-i-access-the-panelview-plus-configuration-menu/
Tech note says:
  1. Connect a USB keyboard to the terminal. Without this, you will not be able to navigate through the PanelView Plus 6 boot menu screens.
  2. Press the small, recessed button labeled Default with a thin non-conductive probe. This will start the terminal in Maintenance mode.
  3. You will then get to the Maintenance Window
  4. Select (by using the left & right arrow keys on the keyboard) Special BOOT Action --> Safe Mode. This option will boot the terminal to the FactoryTalk View ME Station configuration screen
This is a quote from a previous post that helped me in a similar situation....
http://www.plctalk.net/qanda/showthread.php?t=48497
The 'Default' button on the back of the HMI is what helped me some years back.
myke2480,
Hi and Welcome to the Forum!
Something the members have posted above might get you sorted, or has already gotten you sorted out. But for future reference, it is better to post up the full catalog number for the assembled PanelView Plus HMI terminal. This way we can be sure that what you are calling it is indeed correct and that the advice provided may be more specific to the actual model of terminal you are using.
JasonTheSparky,
On a similar note: as we do not know for certain which type of PanelView Plus 1000 is being used here (older PVP, newer PVP 6 or PVP 7?), we need to be careful with not confusing the situation. The info you've posted up contains references to...
This is specific to the newer model terminal menus (PVP 6/7) and is not present in the older PanelView Plus 1000.
Also, the link in your post is for a PanelView Plus 6 model, which again is possibly not correct here, "if" an older model terminal is being used.
If the catalog number is provided we can then be more sure which advice to dispense. Granted, usually when I see just "panelview plus 1000" or similar in these threads, I do tend to think they mean the older models. But it is still better to be sure, isn't it?
Regards,
George
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
169
Hi everyone, I've been tasked with creating a basic HMI for commissioning purposes for two pumps on a AB Panelview Plus 1000, 2711PRDT10C. I have...
2,990
im tring to find out if i have a bad power supply for my panelview 1000 plus. does anyone have the pinout for the 10 pin connector on the...
1,873
I need an X/Y plot to visually represent data o a roundness gage I am designing. ActiveX ME Chart Control UDT seems broke. Any advise one how to...
675
Hello Everyone, I hope we are all good today! I have a project from 2015, and the customer is locked out of the HMI. They do not know what the...
2,016
