5V Encoder, 24V Input
ndzied1
Aug 2002
Chicago, Illinois
2,856
Does anyone know of a device that would let me run one leg of a quadrature encoder signal (say the A channel) into a 24V input at my PLC?
The encoder signal is 5V Square wave, 3kHz Max.
ndzied1,
Any good Signal Isolator (also sometimes called a Signal Converter) will let you put in one range of voltage (say 0-5 vdc) and convert it into another voltage output range, say 0-24 VDC, which will also be isolated from the input.
Hi; I have noticed that at our machines, when pulse frequency of encoder is high, OEM uses 5V encoders instead of 24V. What could be the reason?
2,676
Hi all, i want to use DC motor with the PLC and Block have Pins for encoder input and supply 24v dc. how i can use 5v dc encoder with the PLC block.
2,442
Hello i have an Avago encoder and it gives out a 5V pulse. it is also powered from a 5V supply. my plc has an encoder card that gives out 24V...
7,280
Sorry in advance for the long post, but this requires a little back story. I work in a facility with a couple hundred VFDs Most are in a web...
151
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
242
