Passing parameters from a parameter file into another parameter file
awhite
Apr 2013
NH
17
Bear with me as I try to explain what I need to happen. I'm working with FTView SE 6.
I have successfully created a screen that has multiple page buttons per A-B KB article 44693. With 4 pages, you create 4 memory tag constants, 4 parameter files, and 4 buttons on the display. Each button is connected to a parameter file and with the proper visibility animation, the next/previous buttons become visible.
Per the KB article, the parameter files are configured as follows:
Parm1 #1 = Const\GoToParm4
#2 = Const\GoToParm2
Parm2 #1 = Const\GoToParm1
#2 = Const\GoToParm3
Parm3 #1 = Const\GoToParm2
#2 = Const\GoToParm4
Parm4 #1 = Const\GoToParm3
#2 = Const\GoToParm1
Now I need to create a screen that has two sets of buttons. Selecting a button from group 1 loads a parameter file of constants (same as article). A button from group 2 needs to load a parameter file but needs to maintain the first selection, but change the second.
For example, say I wanted to display a dataset stored in the PLC that is a two dimensional array of a udt. The buttons drive the array indexes of the two dimensional array.
Array[#1,#2].dataset.Item1
Array[#1,#2].dataset.Item2 ... etc
Pressing a button of group 1 loads one of the parameter files:
Parm1 #1 = Const\val1
#2 = Const\val1
Parm2 #1 = Const\val2
#2 = Const\val1
Parm3 #1 = Const\val3
#2 = Const\val1
Parm4 #1 = Const\val4
#2 = Const\val1
Pressing a button in group 2 needs to maintain the value of #1, but change #2. I would like to load the parameter file:
Parm1 #1 = #1
#2 = Const\val1
Parm2 #1 = #1
#2 = Const\val2
Parm3 #1 = #1
#2 = Const\val3
Parm4 #1 = #1
#2 = Const\val4
It doesn't seem to work though KB article 59160 leads me to believe it would. So I either need to correct what I'm doing wrong here or pursue another method.
We're looking to have multiple people/stations viewing different data on different screens at the same time, so the use of memory tags won't work (tried that already, each screen overwrites the other).
Also, the example given has been greatly simplified but directly applicable to how the screen needs to work. The example given above is very simplified. I realize I could just make 8 parameter files and call it good for the above layout. But the actual application would require more than 300 parameter files and 300 buttons to do it in the same manner (there are multiple 3 dimension arrays in the actual system). If I can get the above solution to work, only require 28 parameter files and buttons are required. That quantity is a little more manageable.
Any help is appreciated.
I'm using FactoryTalk ME version 13. I'm aware how to pass a parameter file once, but I was wondering if it is possible to do it twice...
155
I'm developing a program in FTView ME for a machine that has three independent axes of motion, each controlled by an old pneumatic proportional...
2,810
I've developed an AOI for our facility, and it appears to be working well for what I need it to do. (Analog alarm for multiple alarm setpoints)...
2,263
I am trying to create a single routine that can control multiple pumps. My pump tags are all different data types for each pump, i.e. bool, real...
1,502
I am trying to create a common "motor control" subroutine in RSLogix5. I would then "jsr" with parameters once for each motor. No problem so far...
9,541
