Softwre required for Proface HMI GP4402-WW
Pallab Sur
Sep 2017
Mumbai
I need programming software for GP-4402WW HMI of Proface make . I have GX Pro EX 4.07.101 and V4.06.300 but this HMI (GP 4402) does not appear in the selection menu , It apears in GX Pro V4.06.200 Anyone please share the link from whr I can download the software.
actually all version 4.03 and later supports GP4x02WW. if you haven't solve the problem, here's the solution:
Run "C:\Program Files\Pro-face\GP-Pro EX 4.08\OP\YTSetup.exe" once.
No dialog will show up but just some command prompt running. restart the software and you will see GP4402 appear in the list.
Softwre required for Proface HMI GP4402-WW/GP4502-WW
You have to change your folder settings to show hidden files. For some reason they are marked as hidden files.
Sorry for replying to an old post but I wanted to second this solution and give my thanks. Had a GP4501WW panel that my GP-Pro EX 4.08 could not open, with the same error message:
Unable to load project as it is configured with a display unit that is not supported by the editor.
Please define a different file.
Updated to 4.09 to try again. Same error.
Ran YTsetup.exe as explained above, which was a Language Resource Installer, restarted the program, and the file opened fine. What was really tricky was that it could "Read Display Unit" fine, so it could communicate with the panel, just could not read the file.
Hi everyone id like to start by saying im not a PLC programmer so my technical terminology is limited. i would like advice on what software is...
296
Hi all. Please can anyone assist me with a Devicenet EDS File or link for a Numatics G2-2 solenoid valve bank. Need to do configuration on a...
702
Hello everyone. I am working on a rebuilt AB-Ultra series drive (1998) and the firmware for the drive is needed to test and use the drive. I would...
451
Hello everyone, We are trying to upgrade a GE FANUC 9030 PLC, but we are having trouble extracting the program from it. LogicMaster90 is able...
1,305
Hi , Does anyone have any pdf or manual on the GEM 80 Gemlan T card Could you let me know Many thanks Mike
397
