Kinetix 6500 question.
Chris K
Feb 2016
North East
Hello,
I am trying to build a test station for servos using Kinetix 6500, All is well, except when I am trying to run Motion Direct command, beside MAH, MSO, MSF I am getting error "execute on an axis whose servo loop is not closed". What can cause that? It's wiring problem or should I look in the code? Any tips will be greatly appreciate.
A physical axis can't do anything unless it is enabled and actively controlling its own position. The axis is put in this state with the MSO (Motion Servo On) command. You have to issue an MSO before you can issue any motion commands. You only have to issue one MSO assuming you have not also issued an MSF (Motion Servo ofF) or the axis has not lost servo control due to fault or e-stop since the last MSO.
Keith
Thanks for the reply. I am aware of the fact that in order to make motion on the servo MSO command ha to be issued, however, when the command is issued there is no error. Error appears as "execute on an axis whose servo loop is not closed" when MAJ command is issued.
agreeing with Kamenges (and you), the only time I get that message is when the servo is not turned on. Maybe something is turning the servo off after you MSO?
Watch the axis tag .ServoActionStatus. It need to stay true. Maybe it's going false for some reason?
I'm fairly new to dealing with servo motion but I have a fairly simple application I was hoping to get some feedback on. I've got a large load I...
4,629
Dear team, We are constantly facing M07 incremental loss on one of our kinetix 6500 safe torque. We have changed Servo motor (MPL-B4530K-MJ72AA)...
110
Loving AB right now... We have an Allen-Bradley 2094-EN02D-M01 Kinetix 6500 servo drive that once had safe-speed monitoring which was eliminated...
129
Hello, I encountered a problem with the kinetix 6500 drive, error code s22, loss of 3 phase voltage. After disassembling and replacing the thermal...
165
Hi everybody, I am having an intermittent issue with a Kinetix 6500 drive. The fault i get is a SAFE FLT 05, described as GuardFeedback1Fault in...
880
