Advanced HMI - Still in active development? - Also a question re: A.B. ML100
ControlSysNick
Jan 2009
Ontario
54
Hi Archie,
I visited the web site http://www.advancedhmi.com/ and the last news item shown on the site was posted in mid-2013
I have a few questions:
Are you still actively developing Advanced HMI?
I am thinking of using Advanced HMI for a small job that uses an Allen-Bradley MicroLogix 1100 (communicating over the Ethernet port).
Does Advanced HMI require the use of RSLinx? Or does it have its own software driver?
What kind of data sampling rate is possible?
I have a need for charting a couple of variables with an update rate of every 200 msec. Would that be achievable?
Thanks!
Nick
AdvancedHMI is still actively in development.
There are drivers for nearly all of AB PLCs and it does not require RSLinx.
The read rate is dependent on several factors such network speed, the amount of data being read, and computer speed. I have ran a simple test to see what is the fastest possible read rate by reading only a single tag over Ethernet that was connected point to point with a CompactLogix processor. It was able to update at an average of 12ms.
Hi Archie,
Thanks for the quick reply!
I've been meaning to try your Advanced HMI s/w and have got the perfect small project to try it out on. Looking forward to it.
Nick
I have a follow-up question:
Does it matter as to which version of Visual Studio I have installed?
ie. I have Visual Studio 2010 installed and am considering upgrading to 2013. Does it matter as far as Advanced HMI goes?
Nick
I’m new to plc programming and very new to HMIs. So this is what I have done so far: I bought a micrologix 1100, I used bootP to set the up...
17
1,677
So I installed advanced hmi and grabbed an ethernet cable. I have the click C0-12DRE-1-D PLC. I installed the advanced hmi and added the...
2,056
Do I use the ethernet port on the click plc to connect it to my computer. Will advancedhmi work properly? Am I able to start data logging into a...
941
Having a hard time getting the data received when using BeginReadMultiple. Not the most familiar with the ClxDriver and EthernetIPforCLXCom()...
2,325
I am in search of a non-PC based, non-SCADA based HMI and software that allows the ability to dynamically draw graphical objects on the screen to...
5,044
