Texas ascii message card
jed
Jul 2006
Leeds
22
I need to modify a texas PLC which uses an ascii message card (500-5022)to send messages to an Allen Bradley DL10 message display. I think the ascii card needs programming as there are two ports on it and there are no rungs in the PLC code that look like they are ascii. I have the Tisoft 6.2.2 programming software but this does not seem to include anything for programming the ascii card, can anyone help? Is there a programming manual available and what software do I need?
Sorry, Jed...
I just don't have it at hand right now.
I'll see what I can do... if the others that do TI don't jump in first.
Hi Jed
If memory serves me the PLC CPU was a passive element in this ASCII Output Module's operation. You had to use specific module configuration software to get it working. And I don't ever remember seeing this config s/w available for a PC, not even under DOS. The only stuff I ever saw was for the TI VPU-200 programming unit.
There were a couple of stages to configuring the module. First of all was to set up the actual message texts themselves, complete with any embedded memory addresses from the CPU. Then there was identifying the trigger condition (a bit in the CPU) that would cause any given message to be output, and a feedback bit from the module to the CPU to say the message had been done.
The module then just spent all its time monitoring the state of the trigger bits in the CPU. If any one went high, the module would twitch, output the appropriate message, and then write the confirmation bit back to the CPU.
That's my total info I'm afraid - as I re-read this I doubt if any of it has been much use!
Regards
Ken
Hello Ken
Thanks for the quick reply.
Your reply has been of use as you have confirmed my suspicions.
This is the first time I have used this web site.
Jed
I need help writing code that sends one real # out of a serial port (RS232)in form of an ASCII string. The processor is a Siemens (Texas...
2,106
Anyone know of a good place to take PLC classes or anyone looking to tutor a PLC novice in the Dallas, Tx area?
2,649
Hi, Just looking for a quick pointer. I want to upload an old program out of a Texas 305 PLC. The program was last downloaded in the 90s so...
2,033
Upgrading an old TI PLC with a chassis PN 500-5840. has terminals on top and bottom but can't find a wiring diagram earlier. Help!! actually...
943
I have been through a little of bad weather being from SC, the last couple years we have had a few bad ones but being in the upper midlands my...
1,527
