Panelview 600 LCD Problem
Oct 2005
Manila
Hey Guyz,
I have a problem with Panelview 600 unit.
No graphic display can be seen in the display, the graphics seemed to be "dead". Because of this I could not operate the machine.
I tried to access the contrast mode of the Panelview but even if I adjusted the contrast still no graphic display can be seen.
Panelview 600 Cat No: 2711-B6C8.
Can you please tell me who experienced the same and how did you do it?.
JM
Call Rockwell. It has no replaceable backlight. Maybe they will warrant it or something.
This is going to sound like a stupid question but the screen that it is on does have objects on it doesn't it?
I got a call one time to replace a touchscreen. Went out there and it was blank. When I uploaded the file from the processor the screen turned blue and the upload status bar appeared. Turned out the programmer had put a blank screen on the display and a button on another screen to get there
Yours is probably dead though. You have verified that it is getting 24VDC power?
I am trying to go to a 504 CPU. and on my hmi I am getting a 9028 error. can someone explain what they mean by change reference?
217
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
447
Hello, Friends Please someone help me find right cable to communicate Panelview 600 (2711-B6C9) to Micrologix 1200 (1762-L24AWAR). AND any advice.
264
Hello , I have an HMI of PV+ 600 (2711-T6M5D) Ser A Rev B, This HMI doesn't have the ethernet port i have to take backup through communicate...
646
Hello all, I copied the MER file from one PanelView Plus 600 to another one, using a USB drive. On the new HMI, I copied the MER file to the...
624
