Start of single phase AC motor - theory and practice
Pandiani
Apr 2005
Tz
718
Hello guys,
I have a question about how AC motor starts.
Please read file in attachment and comment.
pandiani, there are lots of different kinds of single phase AC motors, each with a different scheme for getting the motor started.
In the most basic form, you need to create a second AC phase that is offset in time with the primary AC power phase. Once you have created this second phase, you use it to create a spinning field in the stator which drags the rotor around just like in a three phase motor.
Many different schemes have been used to create this second AC phase, some of purely inductive, some using capacitors and inductors, and some using simple magnetic methods as in shaded pole motors.
Most of these develop rather poor levels of torque at start so that becomes a key application issue when selecting the right design of single phase motor.
This is probably one of the better pieces of literature for learning about basic motor theory. http://www.aosmithmotors.com/pdf/brochures/bulletin3100/ACDC.PDF
If you go to the section on how an AC motor works you will get the basics, then go to page 26 for a great description of the available types of 1 phase motors, how they work and what their advantages / disavantages are compared to each other.
How deep do you want to go?
You can always find a state space model of an AC induction motor in the internet. There are places like www.ti.com that have application notes on how to control AC motors using their DSPs. Actually, I think that just about every DSP manufacturer has an application note on how to control an AC motor using their DSPs.
I have a customer asking me about using a soft start to start a 2hp 115V single phase motor. It is working fine they just want to soften the start...
1,540
Does anyone have a sample of logic using one button to start and the same button to stop an output. I am trying to do this in RSLogix 500 and due...
49
60,314
How to fix if appears code “$115 plc-restart running” on the screen OP17
244
Hello everyone, I'm new here. First of all I just want to say that you guys are very knowledgeable and reading your posts on here has saved my...
161
can anyone has a good program to learn plc programming online. i have the basic looking into improve my skills thanks
142
