Factory Talk Config
AlanSmith
Mar 2007
Ashbourne, Derbyshire
Hi To All (from new member)
Having a problem with RSViewME. Cannot get the FactoryTalk Configuration wizard to run, it just hangs when trying to configure the Local directory. The FactoryTalk diagnostic viewer gives the following message...
Factory Talk Directory Multiplexor Failed to connect to Factory Talk Scope Directory, in “$Local” scope. The connection may be re-established at a later time. I also get the following error code... Error HResult=”0x80042002” Location= “.\ RNADirServerProxy.cpp Line: 7167
This has happened since trying to re-install RSView after a crash. (used to work OK before)
I would appreciate any advice on how to fix this.
Regards Alan
Hi Guys, Looking for someone well versed in VBA that can either tell me a certain naming convention or point me in the right direction (I'm a...
54
Hi- I am configuring an alarm and event server to display 1 current alarm at a time on a big display. Having a few issues The alarm doesn't...
54
Hi Friends; I have a red Explanation Mark on Factory Talk Directory in Task Bar. Before Update the windows and installation of AutoCad it works...
152
I am trying to enable an external alarm via computer speakers for Factory Talk Network Distributed Edition. I am using Alarm and Events setup. I...
172
