How to merge duplicated WinCC tags?
AlecTek
Sep 2010
Vancouver
155
We had a project: WinCC flexible 2008+ Step7 v5.5. Somehow for each PLC tag there are 2-3 tags created in WinCC.
Is there an easy way to merge all the tags with the same PLC tag?
Not really.
You can search-and-replace for the tags with the names ***_0, ***_1 etc. It is a chore though.
I just delete the duplicate tags, and when compiling the error log will link me directly to the locations of the deleted tags. Not much faster though.
The best is to avoid getting the duplicate tags in the first place.
When you copy-and-paste objects between projects, be sure that you dont change for example the connection name in the different projects. If the connection name is different flex will assume that the tags are different and then create the duplicate tags.
Oh, and you can experiment with the "flat copy". It may help in avoiding getting the duplicate tags.
Flat Copy
When you copy screens or other objects in WinCC Flexible you have a choice of "copy" or "flat copy". If you copy a screen from one HMI to another I usually use flat copy. If part of the tags in the screen already exist in the other HMI duplicates are created. The disadvantage is you have to browse to the location in the PLC data block or symbol to include it in that HMI. Everyone please let me know if I explained this incorrectly, or was too brief.
Hope this helps.
Hello, besides a post on this site from 2016, I haven't seen any questions or answers regarding this. Is if it is possible to strip the RSLinx...
1,561
Is there a simple way to merge the description off line for RS 5000 Like RS 500 I am new to RS5000 and have several applications running that have...
1,071
dear friend, i use rslogix 5000.I have a program consisting of several ladder diagrams.is there a way to merge them in only one logic diagram to...
1,639
I have 2 different .RSX (RSLinx configuration) files. I would like to make them one file. Is there any way to merge these files?
1,820
How do you merge off line a rs 5000 program with one that has descriptions on the tags. I have done rs 500 but never 5000
1,453
