Configuring midimaster drive using STARTER software
mikas_m
Feb 2007
ck
154
Hello,
I need to configure two midimaster drive and set up most of paramteres to be exactly the same as paramters of a third drive that is currently in operation. One way is to manually go through all parameters by using operator board. Other much faster way would be to upload all parameters with some software and download same configuration to other drives.
Now I have got Siemens STARTER software that can be used to configure Micromaster drives. My biggest problem now is what cable to use it to connect PC (notebook) to midimaster drive?
Should it be simple NULL modem cable?
Do you have some experience with this issue?
Kakka, I'm not sure what you mean... What profibus cable? It's more RS232 or Null modem to me. I have USB and RS232 port on my notebook. Do need some special adapters, as well?
You can use profibus cable but you need profibus card in your midimaster + mpi/profibus adapter in your pc
USS protocol is the cheapest way is using RS-232 null modem pin 2-3,3-2,5-5, and you have the converter module (detach AOP/BOP). But I never triy it.
Regards,
Anton
good day.
just need some info? is it a midi master or a mm440 drive?
can you supply a mlfb no.(siemens part no) the starter softwear was made for the mm4 drives and the sinamic as wel as the simotion drives not for the old gen midi master drives.
if you whatn to use the starter on new drives prefird conection is profibus dp.
For your situation i segest u use drive monitor and you can just save your parameter list and download it to the drives. you will also requir a rs232 to rs485(uss) converter for the midi master(or profibus modul on the drive?
i can help you more in detail if you give me the part number.
Hello all and happy Friday, I'm curious if anyone here has experience sending data over an Anybus Bolt II (HMS AWB6001-A) using a Compact Logix...
769
Hello everyone, I am looking for an easier way to configure all my IO for an OPTO22 PLC. I am developing in Codesys I have a GRV-EPIC-PR1 with a...
585
Greetings to all. We have SST-SR4-CLX-RLL (Molex Modbus module) in remote backplane. The remote backplane, containing SST-SR4-CLX-RLL module, is...
652
disclaimer- 1,no one in their right mind would pick this configuration but I want to try and get it working. 2, my MB knowledge is sketchy at...
1,139
When configuring redundant ethernet cards, will the mac address change along with the IP address. A friend is having problems with IP security...
1,260
