EtherNet/IP ERROR Code 0x02 (Resources Unavailable)
mihiri
May 2010
Newcastle
22
Hello All,
I am trying to configure a Modbus Master(Xport-EIP-MB adaptor{Acts as a Modbus Master}, this device converts a Modbus RTU server into a EtherNet/IP server) device to communicate with a Modbus Slave (Which is the Modbus RTU server).
The Modbus Master/Client send a Modbus message to the slave device to test if the supplied data are supported in the slave. If there is no response from the slave, the EtherNet/IP error code will be 0x02 (Resources Unavailable).
The Xport EIP MB device is a very neat device where we have designed a PCB to incorporate the this module with the industry standard RS485 Slave Modbus RTU communication port.
A ControlLogix5561 PLC is used to directly communicate with the Xport modules EtherNet port. I am receiving this error message at the point where I am trying to send a specific message to the Xport module, which then tries to verify with the Modbus Slave.
Can someone explain to me what could cause this error ? to me it seems like the master has trouble accessing the slave for some unknown reason at this stage.
Thanks for the help :geek:
Cheers
Since that thread never got off the ground and has a different set of facts (an embedded unit, not an external well-known Modbus product) I'd say set up a whole new thread.
Start at the level of the Forum, use the "Start a New Thread" button, and post as much information as you can about the physical connection, the configuration, and the operation that you're trying to make happen.
Hello, I was trying to communicate Mitsubishi F800 Ethernet Communication With RSLogix 5000. I could able to ping VFD & PLC from laptop, but in...
4,811
Using 1756-L61 plc. Have a msg instruction for a 1756-ENTB that has no normal error but has a extended error code of 16#0000_DD14. Has anyone...
7,934
Hi All ... In one full plant, all machines are connected to networks. above 500 ip address... that consists of plc,servo,hmi and third party...
1,545
Hi, I am using P&F - WCS reader to read position of a trolley motion on a crane. Sometimes there is Ethernet communication failure error given by...
1,041
Hi everyone, I'm currently configuring a Q-series PLC (Q10UDEHCPU), using GX Wroks 2, and a Q71E71-100 Ethernet communication module to...
2,234
