Flex Ex IO options
cardosocea
Nov 2016
Fields of corn
2,632
Hello gents,
I have a few Flex EX IO units deployed in a CLX system and I can't get parts to maintain the system anymore. I started looking at Rockwell to use their Ex IO, but honestly after feeling the bite of being left out in the cold with no option but to upgrade the entire bus and IO system, I am looking into options.
Has anyone have experience in other systems that I could use that are intrinsically safe and can be installed in Zone 2 area (a panel with IP54 exists already)?
I've looked at a couple of options but it would be nice to hear from other people about hteir experiences.
One option is to fit a Profibus master card, an isolator and use the ET200iSP from Siemens.
In the same vein, with Profibus I could use Pepperl and Fuchs (which Rockwell doesn't allow with EthernetIP) and potentially also Wago.
This comes after someone challenged the idea of keeping with Rockwell when Siemens, with their market share and accepted protocols, makes it simpler to maintain systems... which is hard to argue considering the ridiculous prices from Rockwell.
Hello all. I have a parts elevator in a very dirty environment. I have used VFD's a lot over the years but I have never had to have one with a...
1,768
I was looking at parameter 190 for the 700h and I trying to figure out if this would disable the option for a technician to walk over and put a...
2,055
Hi I havent found it so I suspect it is not possible but has anyone implented a flexgrid onto wincc flexible 2008? I have approx 200 parameters i...
4,548
Hello everyone, my son and I are working on building a metal lathe. I been waiting for a motor/speed controller donor from a treadmill. I finally...
44
I've got a Powerflex 700 that doesn't like to get going in the mornings. This motor will run anywhere from 30 seconds to 5 minutes before it just...
154
