plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old April 6th, 2018, 03:52 AM   #1
theripley
Philippines
theripley is offline
theripley's Avatar
OT: Machine
Hi all.
Do you know any machine that can take out the molded transparent plastic without scratching the black one?
The transparent plastic is known to be grilamid.
Any idea will be greatly appreciated. Thanks.
__________________
"Complacency is the enemy of greatness"
Old April 6th, 2018, 04:43 AM   #2
CommissioningMan
Denmark
CommissioningMan is offline
Seems more like the black plastic needs to be taken out of the Grilamid mold?
Are either of them flexible? Otherwise I don't see how you can remove either one, without damaging at least one part.
If you need to fixate the black tube, you could insert something like an inflatable tube into the black tube?
__________________
All things Siemens and Beckhoff. Please let it be Beckhoff.
Old April 6th, 2018, 05:18 AM   #3
Aabeck
United States
Aabeck is online now
Aabeck's Avatar
How about making a fixture for an arbor press that holds the clear plastic with the black tube pointed up, securely holding the bottom of the clear part.
Then make a head for the arbor press that fits inside the black tube to hold it so it does not deform and a flange presses on the top of the tube and pushes the black part out of the clear part.
__________________
Never underestimate the quality of idiots that will be running your machines
http://aabeck.com
Old April 6th, 2018, 05:59 AM   #4
BryanG
United Kingdom
BryanG is offline
Before thinking about a machine to do the job, how do you do it manually? If you can't figure a way to do it manually then you will never get a machine to it.
Air pressure doesn't tend to scratch things but can be a bit weak, water pressure can move mountains.
Old April 9th, 2018, 07:36 PM   #5
theripley
Philippines
theripley's Avatar
Quote:
According to them, they do it through machining. However, they are complaining of damages on the black.
__________________
Old April 10th, 2018, 02:19 AM   #6
BryanG
United Kingdom
BryanG is offline
So as I said, can you 'blow' them out, air won't scratch. The clear plastic has grooves that would be easy to grip and hold a seal against the end.
Old April 10th, 2018, 02:54 AM   #7
AutomationEngineer82
Sweden
AutomationEngineer82 is offline
Sorry for using this thread for something not related. But I am sick and tired of searching this homepage for a button or link with which I create a new posts. I already now how to reply to other posts. I have spent ten minutes now finding practically anything BUT that funciton.
Old April 10th, 2018, 03:16 AM   #8
rdrast
United States
rdrast is offline
rdrast's Avatar
Quote:
Upper left. "Start a new thread".
__________________
How to ask questions the SMART Way!
Look First, Ask Second!
Old April 10th, 2018, 03:41 AM   #9
theripley
Philippines
theripley's Avatar
Grimalid cannot be blown out, it is non-flexible.
We are trying a cutter this time. I will keep y'all posted.
__________________
Old April 10th, 2018, 05:24 AM   #10
Mad_Poet
United States
Mad_Poet is offline
Is the transparent part brittle?
If so one might try 'scoring' the transparent part around the 'elbow'
then crack it apart and separate it.
Poet.
Old April 10th, 2018, 07:15 AM   #11
kekrahulik
United States
kekrahulik is offline
Liquid Nitrogen and a careful tap of a hammer?
__________________
_______________________________________________
"Get it right the first time" is a great philosophy, but when that doesn't happen, be persistent and "Get it right the last time".
Old April 10th, 2018, 11:09 AM   #12
Lare
Finland
Lare is offline
inner part don't look special. Isn't it available without clear outer part?
Old April 11th, 2018, 02:15 AM   #13
BryanG
United Kingdom
BryanG is offline
The obvious question isn't 'how to get the part out', it is 'why manufacture it like that in the first place?' Putting that much effort and material in to making something that you are just going to throw away is wasteful and bad for the environment. They really need to look earlier in the production process and find a better way.
Old April 14th, 2018, 07:06 PM   #14
shooter
Netherlands
shooter is offline
shooter's Avatar
a very simple tube is enough, just buy it, or call the company that makes it as it is out of two parts fabricated.
__________________
shooter@home.nl
skype shooter paul.deelen
Computer Shooter
Paul Deelen
J. Wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
+31653300739
Old April 15th, 2018, 08:44 PM   #15
theripley
Philippines
theripley's Avatar
During re-processing, they only need the black part. I think the black part is more expensive to produce that is why they wanted to re-process it.
As for the liquid nitrogen, it is worth a try. I will buy a liquid nitrogen & see if it will not affect the black.
By the way, I am attaching pictures after we use cutter in trying to separate the two. It makes major scratches, which is definitely not acceptable
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Older Injection Molding Machine conversion to a PLC? kickford1 LIVE PLC Questions And Answers 18 February 2nd, 2014 11:09 PM
OT - Machine timing strobe Norml LIVE PLC Questions And Answers 3 January 14th, 2009 09:03 AM
Machine status monitoring system? Anyone come across this? flyers LIVE PLC Questions And Answers 13 April 16th, 2007 11:29 AM
One PLC, One machine V's One PLC, Two Machines Mylo LIVE PLC Questions And Answers 13 March 4th, 2005 04:38 AM
Plc For Simple Machine 32racer LIVE PLC Questions And Answers 5 December 6th, 2004 12:16 PM
