plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old April 14th, 2018, 10:21 PM   #1
eckert16
United States
eckert16 is offline
CP01R-04 Configuration Mode & Designer 6 'Communication Error'
We've purchased the Designer 6, loaded it onto the laptop, connected the provided cable between the laptop and the UniOp, and get 'communication error' while attempting to read the HMI data.
We've determined that the UniOp is not in 'Configuration Mode', however, the UniOp will not permit selection of CNFG (configuration)... it appears to be locked out. Is there a way to force the UniOp into 'Configuration Mode' besides holding the ENTER key for more than two seconds (which is only allowing selection of a few items...one not being Configuration)? We've held the ENTER button down for more than two seconds, and it does not permit use to select configuration.
The UniOp also has the only copy of the program we are attempting to download to Designer 6, so we can determine the passwords in the UniOp program. We'd like to force the UniOp into Configuration Mode in order to permit Designer 6 to download the HMI program from the UniOp, and onto our laptop.
Old April 15th, 2018, 01:19 PM   #2
eckert16
United States
eckert16 is offline
Been following the directions from the Designer 6 manual. The UniOp won't 'arrow over' to the 'cfg' to permit us to select it.
Old April 15th, 2018, 03:30 PM   #3
eckert16
United States
eckert16 is offline
From Yaskawa, I found another manual with further instructions I'm hoping to try tonight.
Troubleshooting
If the operator panel cannot be switched to Configuration Mode due to problems in the start-up phase, follow the steps below:
1. Switch off the unit.
2. Press and hold any 3 keys.
3. Turn on the unit and continue holding the 3 keys until Configuration Mode is
shown on the screen.
For keyless models such as the ETOP-10, ETOP-11, ETOP-12, ETOP-30, follow the steps below:
2. Touch anywhere in the middle of the left side of the display screen.
3. Switch on the operator panel and tap anywhere in the middle of the right side
of the display screen for approximately one second.
4. Continue until the screen shows the Configuration Mode.
Old April 15th, 2018, 08:10 PM   #4
eckert16
United States
eckert16 is offline
That did work to get it into configuration mode (disconnect power, 3 button hold, reconnect power). Using this forced process did not erase the UniOp contents.
Next step is to Upload from the UniOp to the Designer 6 program.
However: on upload, the Designer 6 program identifies a Protection Mode
I thought we'd be able to Upload from the UniOp directly into the Designer 6 program....
Any ideas on how to get the program stored in the UniOp Uploaded into Designer 6?
We do not have a password (which is why we've gone thru all these stages), as the company that made the equipment went out of business over 10 years ago.
Old April 16th, 2018, 01:30 AM   #5
bkottaras
United States
bkottaras is online now
It's been a while but the default/factory password used to be"11111" or maybe 6-1's.
Old April 16th, 2018, 08:14 AM   #6
eckert16
United States
eckert16 is offline
Thank you, I just tried the series of 1's, and that did not permit the upload to occur. This HMI is on a car wash, Futura, by Specialty Equipment Company.
Old April 16th, 2018, 12:06 PM   #7
sigmadelta
Canada
sigmadelta is online now
try "4444" or "7777"
__________________
Freelance Automation Programmer
Old April 16th, 2018, 12:16 PM   #8
sigmadelta
Canada
Actually, try "0007"
__________________
Old April 16th, 2018, 01:15 PM   #9
eckert16
United States
eckert16 is offline
I appreciate the numbers, I've also tried other 'numbers' from the manuals that didn't work either, such as:
Model SFRP-3600
Serial 1860
Order 38847
Model C530
Model P01000F
SSA-0100C-Mill Drive
Serial 1697
Model E-546
CAT-3535
10105981
3B56Q
3TB-124
BX-68
H709
2G56C
Foam Wax: 2988
Spot Free: 9907
PLC: U1.0R1
Level 1 user 1613
Level 2 manager 1450
Level 3 service 1757
Old April 17th, 2018, 08:10 PM   #10
eckert16
United States
eckert16 is offline
Attempting to get a password on a 18 y/o piece of equipment when the mfg went out of business 10 yrs ago can be a struggle.
Designer 6 shows the 'Upload Protection' in the UniOp HMI is active, and prevents getting the program from the UniOP into Designer 6. On HMI inspection, it seems the program is stored in the AM29F010-70PC CMOS chip.
I bought a spare UniOP to see if I can figure out an alternative means to get the Upload Protection password...am considering putting an 'Upload Protection' dummy HMI program into the spare UniOP, then pulling and dumping the ROM chip data, then scrolling thru the data to determine the location of the 'Upload Protection' password in memory. Then I'll try it again once or twice more, before going to the live UniOP on a rainy day.
Old April 18th, 2018, 04:59 AM   #11
sigmadelta
Canada
Theoretically, you could read out the EEPROM, and write it to the spare one, and you would have the spare unit ready to install, in case you don't get the password.
__________________
Old April 28th, 2018, 10:03 AM   #12
eckert16
United States
eckert16 is offline
Thumbs up
Got the password recovered. Thanks for the advice folks.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Retentive data lost Micrologix1000 Deer LIVE PLC Questions And Answers 15 March 23rd, 2018 09:28 PM
Host communication error 00h Wtech67 LIVE PLC Questions And Answers 2 August 4th, 2015 01:18 PM
ControlLogix 1756-L61 communication error bkfrodo LIVE PLC Questions And Answers 7 March 12th, 2011 07:56 PM
FC AG_SEND and AG_RECEIVE cfbosch LIVE PLC Questions And Answers 10 December 3rd, 2008 03:00 AM
MPI comunication Manuel Raposo LIVE PLC Questions And Answers 22 July 16th, 2007 06:24 AM
