PILZ PAScal V1.9.0 not compatible with Rockwell SISTEMA Library
Hal9000
Jun 2010
London
140
Hi there,
The Pilz PAScal tool (V1.9.0) will not allow me to import the Rockwell SISTEMA library (V2). It appears PAScal will only import older library versions up to V1.1.6.
I have emailed Pilz about this and awaiting their reply.
Does anyone know if there is a workaround for this issue?
or
Does anyone have an older Rockwell SISTEMA library they could kindly post? i.e. 1.1.x ?
Regards,
J
My understanding is that a couple years ago, most of the major safety vendors agreed to a new standard for sharing of safety data libraries (basically, a new file format). Some were faster to adopt the new standard than others, might be related to the incompatibility here.
Pilz basically got back to me with; "The latest version of PAScal uses VDMA format files. Unfortunately not all manufacturers are using this format (such as Rockwell). If you wish to use Rockwell components in our PAScal software then you will need to create these as a custom component."
Hi Guys, I'm trying to integrate Pilz Ethernet IP Module to ControlLogix. I added Pilz module as a Generic Ethernet module and I'm able to...
510
Long shot, anyone got the Pilz PDIA 2 Step 7 drivers zip file they could send me?
1,187
Dear All. I need comm between Compactlogix/Controllogix with PNOZ m1p ETH. What we need the communication option? or can be connect direct? many...
1,179
Hi Guys, First post here! I'll be working with PILZ Safety in a few weeks time, it will be communcating with Allen bradley, Studio 5000. I...
2,838
Hi guys, how to do connect "Pilz 772138" on hardware like the pic? is it possible? I am newbie on Siemens. Thanks
2,316
