PowerFlex 70- HIM Copycat- Can you copy to a drive that is not the same HP , etc.
Cydog
Feb 2018
Maryland
313
Good Morning ,
Had a PowerFlex 70 go bad . Uploaded the parameters to the HIM . Did not have the right drive replacement . The HIM says that the drive doesn’t match , can you somehow override that ?
Thanks so much ,
I have never tried a copycat with a different HP, but I have done it with different firmware levels. The message that came up was a warning, but it allowed me to continue. I am sorry, I don't remember the wording of the option to continue, but it did allow me to do it.
I just did this about three weeks ago. One warning: if you are changing the assignment of inputs from the factory setting, make sure they are off when you change their value. If not, a bit will get set in the drive and not get updated. Our application uses input 6 as an enable input. It happened to be ON when I set parameters. The factory setting for input 6 is Preset Speed 4. Because that input was on when I powered up the drive and changed the input 6 assignment, it kept the bit that selects Preset Speed 4 high and I could not change drive speeds even though I configured the speed reference source as Port 5. I had to reset the input 6 back to Preset Speed 4, then shut off the input, then reassign it back to Enable. That cleared the issue.
Some guidance here would be appreciated. I'm commissioning a system that has several drives installed and configured. One of the motors/drives...
8,826
I've got a Powerflex 700 that doesn't like to get going in the mornings. This motor will run anywhere from 30 seconds to 5 minutes before it just...
160
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
261
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
172
Hello everyone, I'm new here. First of all I just want to say that you guys are very knowledgeable and reading your posts on here has saved my...
168
