Getting data out of a Micrologix 1100 - newbie questions
Autonomic
May 2017
Adelaide
Hi everyone
Just as a disclaimer I'm new to PLCs in general so I apologise if I'm not making any sense.
In a nutshell I have a Micrologix 1100 PLC which is connecting to a machine that counts products. What I'd like to do is access the data (ideally in real time - not sure if this is possible from my research) and export it to an excel file on a PC somewhere.
So far from my research it seems I have to do the following:
1. Connect the PLC to a PC.
This requires a crossover cable to configure the IP (via BOOTP) and then a patch network cable to access it afterwards. Alternatively they can be connected to a switch.
2. Use RSLinx + RSLogix to connect and view/configure the PLC.
I understand the process to open the PLCs configuration in RSLogix (I have the free version - RSLogix Micro Starter Lite). But at this point, assuming I can see the node that contains the data I want, would I be able to export it to a CSV or similar data file? Can the PLC be 'running' normally while this is done or will this interrupt its normal functionality?
I'd appreciate any help.
Just a couple of quick points to help you decide which route to take. If you want the data from the PLC real-time into Excel then you're going to need a paid version of RSLinx - the lite, free version doesn't support this. Alternatively, the ML1100 actually has a built in data logging instruction that actually works quite well. You can download a free Rockwell utility to extract the logged data and open directly in Excel.
This has been covered several times, so you won't have any trouble finding sample code for the data logging on here. Likewise for the real-time Excel route - there will be numerous posts covering this if you search.
Hope this helps.
Regards,
Rob
All, I have a CompactLogix L33 and would like to get data from a height gauge. The gauge is a Fowler Sylac Mark VI with RS232 output. I can...
2,609
Hello I am hoping someone here can maybe at least tell me what I shlould read up on or if this is even possible. Rockwell Studio 5000 is my...
4,280
Hi, Guys I'm trying to upgrade a device witch comms is thru a RS232. The PLC is a Compactlogix L16ER to a remote PIO 1734-AENT then on this PIO a...
22
8,225
Hello Eveyone, I need your advice on one problem.I am using CompactLogix PLC.I am looking for some ways.So, that a PLC program can read data from...
26
13,247
Hi all, I'm trying to use the Data Preserve Tool for Logix5k (CompactLogix controller) but I keep getting comms errors and I'm not sure why. I've...
4,059
