Ink Jet Printers
craigsimon
Apr 2002
Minnesota
93
I have an application that I am designing that will print on the side of a piece of painted materal. We would like to print with an ink jet printer. I have been in contact with VideoJet and they are working on finding me a printer that will do what I want. I would like a print head that will print numbers 90 degrees from normal printing. Normally the printer will print from left to right or right to left as the part moves to the right or left. I still need the part moving from the right to left, but the numbers are printed horizontally. ie. the top of the number is on the left and the bottom is on the right. The number I need printed could be from 1-60. They don't seem able to do this without using symbols and they don't think they could store enough symbols. Sorry about the vague and hard to understand description, but does any know of other ink jet printer manufactures?
I am not clear on some of the "I wants". What do you mean about 90 degrees from normal printing, most inkjets can be mounted horizontally or vertically but they can not print around cornets. Any "good" printer will position the numbers as needed...ie the number is 12345 and the product moves left to right then it will print in the order 54321 because it prints right to left...the number will read 12345.
Anyway, from what I can tell, it sounds like an application that needs a multi-head printer. These are used to print multiple numbers/characters at the same time, works great when printing west to east on an object traveling north to south...this what you mean about 90 degrees?
http://www.trident-itw.com/Catg2.asp?Cat1ID=1201&Cat2ID=317
http://www.matthewsmarking.com/products/index.php
Thanks for all the response. I will look into all of these printers.
It is hard to describe what I need.
The picture above might show it better. The numbers are turned 90 Deg. to the direction of the product flow. Some printers can print turned, but the result is a towered look like this.
I can not use this.
Thanks again
What is the material metal, plastic, fabric?
If metal or plastic laser may be better on low power.
Biggest problem is safety issues then with lasers
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
89
Hi everybody, I would like to know if anybody here has already programmed with a LR-TB keyence on Io Link on a Rockwell PLC? And perhaps have...
76
Hi everybody, Is anybody here still have programmed a Keyence sensor LR-TB2000CL and used it as io link material in studio 5000. I would like to...
89
Hey there friends, recently discovered the world of industrial automation and learned what this fancy PLC can do so i am a super novice. Started...
335
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
105
