How to drive mycom stepper motor using omron CP1L series
Majinuddin
Sep 2014
Batam
Hi I am a new member and need your advice;
I have a set mycom motor driver and stepper motor 5 phase, and need to control using PLC, now i want to buy the mini plc omron CP1L series but i am confuse to the models which model compatible for my project, the models are :
1. Model CP1L-M30DR-D : Relay output
2. Model CP1L-M30DT-D : Transistor output(sinking)
3. Model CP1L-M30DT1-D :Transistor output (sourcing)
Thanks Regards_ Majinuddin
It appears that the Mycom stepper drivers use a line driver (5 volt) input.
You will either have to use a CP1H-Y PLC which has line driver outputs or make a custom cable with series resistors to drop the voltage down from 24vdc to 5vdc. A 2.2k series resistor will usually work.
Dear brother, Osmanmom, Tom, Mendonsy thanks and appreciate your help.
I will choose it that using transistor model.
Majinuddin
Anybody can give me ladder diagram to drive steper motor using cxprogrammer ,please ? i just get the quiz from my teacher Anybody can give me...
1,804
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
317
Im trying to install a Siemens upgrade license using Automation License Manager v6.0. I clicked D: mistakedly, and now I can not find a way to...
74
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
65
Hello everyone, my son and I are working on building a metal lathe. I been waiting for a motor/speed controller donor from a treadmill. I finally...
68
