problem copying screen with faceplate in wincc 2008
Rafiplc
Jul 2016
Valence, Spain
Dear all,
I'm having problems trying to copy a screen with faceplate from one project to another. When I try to paste into project B from project A, it spends a lot of time copying the tags of the faceplate structures. I have left it for more than 8 hours and it does not end! Any idea what could be happening ??
Thank you very much!!
Can you make a global library and put the faceplates in there? Then pull up your other project and add the faceplates from the library.
8 hours sounds like something is wrong..
Finally I left it copying from one day to the next and everything was copied, but I still do not understand why it took so long. It is strange, but in the project from which I copied, I did not have the faceplate in the libraries, only the instance. It is likely that I will have to repeat the process in other projects, and this has not been very efficient to say.
The project on the operator workstation keeps disconnecting, even though I have an installation server and operating station set up through...
23
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
39
I have one old Ansaldo VFD from 37kW and it have only sign OFF on the display after put it on the 3x400VAC. Is there any idea, how to solve this...
37
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
487
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
66
