FTView Objects with any Text is displaying ?
daba
Jul 2004
uk
5,401
I have a version 3 ME Project opened in Version 5.10 FTView.
Every thing that contains any text is displaying "?"
I'm told there is a Knowledgebase article 33856 that explains everything.
Can someone with TechConnect contract access it and tell me the nuts and bolts of it please.....
TIA
Basically the TN says that the original project was imported without a language option being configured. When you import it, select the correct language.
Thanks John, but I didn't "Import" the project, I just put the HMI Project in the HMI Projects folder and it allowed me to open it in V5.10.
Unfortunately the guy who did this job many years ago did not make an archive of the project (.mea), so I've only got the HMI Project Files and Folders to work with.
I can put all these "texts" back if necessary, but it's gonna be a PITA....
All sorted, just had to add "English (UK)" and set as the default language in FTView, and re-opened the project....
I am trying to modify screens and many of the objects are grouped. Can you show me where the ungroup button is? Thanks!
690
Hi All im using Factory Talk SE 7. I want to add a OLE Object "Microsoft Excel Chart" and using VBA link my online tags troug RSLinx Enterprise to...
2,006
Hi guys, I have a question about Global Objects. I have a project that uses Global Objects on a Compact Logix L72 and FT View SE 6.0. I have...
4,218
Hello Reader..! While working on an application on FTview SE I was unable to get the text related to the global objects..! I am using Plantpax...
3,727
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
167
