Please recommend the right PLC among Allen Bradley PLCs
vislab
Feb 2005
20
Hi everyone,
Now I am considering to use one out of Allen Bradley PLC products for my simple project. In my project, first the PLC receives the signal from the PC through RS232C port to initiates the PLC routines and activates the a couple of solenoid valves to operate cylinders and sends error messages back to the PC. The PLC needs to be programmed user friendly because I am familiar with OMRON CPM2A ladder programs. And important thing is that the PLC can give light alarm for warning. But I dont know which one will be the right one for the following required specs. And also I need the PLC that has an ability to communicate with PC through RS232C port.
# of Inputs : 4
# of Outputs : 6
Input types: both Digital and Analog
Output types : both Digital and Analog
Input power: AC or DC24V
Output power: AC or DC24V
Thank you,
I would recommend the MicroLogix 1100 or the 1200 with two ports. You could do it with a MicroLogix 1000, but using analog I/O omn it is a pain. You will save the slightly higher hardware cost by savings in programming.
What Tom said.
But I don't think the MicroLogix 1000 will work due to the need to parse RS232C data from a PC. Unless the PC is speaking DF1.
Oh, thanks for your recommendation. Then I will look up the MicroLogix 1100 or the 1200 to see if which one we can choose. I hope its PLC programming is almost same as I have done with OMRON PLC or not much different.
Thanks.
Hello all, Is any good analyzing software. We have a bunch of data in text files. Need to analyse. Right now we are using DIadem. Is there any...
2,269
If you were going to go down to the closest overpass or homeless shelter to hand pick a person to install, program, and tune 1/16DIN panel PID...
5,783
Hi Guys, I've just finished developing my user interface for our product. Its done in .NET (C#) and interfaces with MicroLogix 1400 & 1100's...
1,931
I hope someone will recommend a small (read inexpensive ) PLC or relay of some sort. It needs to have 4 24vdc digital outputs 1 4-20 MA input 1...
2,196
I met the problem when design the control cabinet sometime does not match with the side of material (the enclosure too small after installed the...
5,795
