Is communication with PLC-5/30A and 30C over Ethernet/IP supported?
m.nazish
Sep 2008
India
39
Is there any connection between Ethernet/IP and PLC-5/30A or PLC-5/30C? I mean if we use PLC-5/30A or PLC-5/30C for communication with Ethernet/IP, will that work?
Please help.
URGENT!
Thanks in advance!
You'll need an e-net side car module. Check the AB web-site for series
and revision compatibility. In addition, if the side-car is an option
you'll have to free up the slot right next to the PLC.
Good Luck
(8{)} :) .)
(Yosi)
So u mean to say that communication with PLC5/30 series A and series C over ethernet/IP is possible but the processor require e-net side car module?
There is also the possibility to use a 1761-NET-ENI connected over serial port of your PLC-5 if it is free...
Just it is not a "direct" ethernet connection, but it is bridged over serial port (speed max 19200 bps :cry: )
- [font=comic sans ms,sans-serif]fuzzy logic[/font]
In our production plant we have multiple different networks (subnets). IT dept have setup routing between them so different subnets can...
49
Is it possible to connect a PC with running WinCC Advanced or Unified to a siemens PLC such as S7-1200 across different subnets? The computers can...
54
Hi good day Everyone, I have a cimplicity v10 project with 7 to 8k tags communicating with AB PLC through OPC and Rslinx classic. I have this...
82
Hi Everyone, I am currently trying to communicate ControlLogix PLCs via EtherNet/IP with Delta V DCS. There is a VIM2 card configured for...
183
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
39
2,076
