Timing Product Gaps
BadGana
Feb 2018
Michigan
Hi Guys,
I want to use a SLC 500 to time gaps between products on a production line. This is part of a project to reduce variability in gaps between products.
Is there a solution to time these gaps and then store them into a data table in a way I could export it to an excel spreadsheet?
I'm assuming I'd use something like an XIO bit enabling a RTO and storing the accumulated value each rising edge of the XIO and resetting the RTO.
Let me know your ideas.
Off the cuff -
Using some sort of detector for product vs no-product, and knowing when the line was running(don't want to time when the line isn't running, pointless).
Start a timer, end when you see the next product, copy the elapsed time to a data table using a FIFO perhaps.
Or, if you have a hmi/scada that can record data(maybe something like AdvancedHMI) just record each 'elapsed time' as it occurs and forget the whole FIFO nonsense.
I have a product that i need to time the feed rate of product delivery to a machine (for display purposes only at this stage). i want to trigger...
1,466
Hello, I am struggling to figure out some logic. I have an analog pressure sensor coming into the PLC and would like to have multiple timing...
129
the plant I am supporting uses a siemens graph function to do some of the step procedures. in several steps it waits for the step to execute for...
755
All Using a MicroLogix 1400. Not a huge program doing an auto stop function based on a calculated roll diameter Using encoder feedback for...
3,192
Hi all, I'm trying to fully understand the different effects of the Loop Update Time parameter within the Logix PID instruction. I was always...
18
4,552
