plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 13th, 2016, 02:58 AM   #1
calamwill
England
calamwill is offline
calamwill's Avatar
Data Tagging from Micrologix 1400 to Red Lion HMI
Hi guys, it's the noob again.
So i'm currently in the middle of communicating between a Micrologix 1400 PLC (programmed via rslogix 500) with a Red Lion G304K200 HMI (programmed via Crimson 3), and it was thanks to you guys that i got this far, thank you for that.
But what i want to know now is:
Is it even possible for me to use the data tags from rslogix 500 in the RL HMI to use the buttons on the screen that i have laid out, in Crimson 3? The buttons would equate to B:3/.. bits in the rslogix 500 software and i can't seem to get them to come through no matter what i do.
Old January 13th, 2016, 07:04 AM   #2
jstolaruk
United States
jstolaruk is offline
B:3/.. Is not a valid address. B<file#>:<word#>/<bit#> is the form that is expected.
__________________
"You can live to be a hundred if you give up all the things that make you want to live to be a hundred." Woody Allen
Old January 13th, 2016, 07:06 AM   #3
calamwill
England
calamwill's Avatar
Quote:
you know what i meant ...
is there any way to get the bits as tags from rslogix 500 to crimson 3?
__________________
I hope my "get-up-and-go" doesn't one day get up and go
Old January 13th, 2016, 07:12 AM   #4
TWControls
United States
TWControls is offline
TWControls's Avatar
First you'll need to configure your communications to something like this...if over Ethernet.
Then select the tag you want to link to the B3, select the source as the PLC you configured above then select your data address.
Old January 13th, 2016, 07:14 AM   #5
calamwill
England
calamwill's Avatar
is that individually for every tag?
and thank you
__________________
Old January 13th, 2016, 07:15 AM   #6
gbeaker
Canada
gbeaker is offline
Create a new flag tag
Source -> your plc (you must have configured the communications already) B003:0000 for B3:0
Extent -> One Item
Treat As -> Bit Array - Little Endian
Bit Number -> 0-15 (0 = b3:0/0 and 15 = b3:0/15)
edit: someone beat me to it with fancy pictures.
Old January 13th, 2016, 07:17 AM   #7
TWControls
United States
TWControls's Avatar
You only add the PLC to the communications once. Then a tag much be mapped for every data point you want to use
Old January 13th, 2016, 08:04 AM   #8
calamwill
England
calamwill's Avatar
OK thank you!
__________________
Old January 13th, 2016, 10:59 AM   #9
padees
United States
padees is offline
padees's Avatar
I just export the tag DB from RS500, then import it into Crimson 3.
Get's them all at once.
Old January 13th, 2016, 03:28 PM   #10
ASF
Australia
ASF is offline
I'm not sure if we're all saying the same thing, but here's some more pretty pictures of the way I do it. First, yes, you need to set up your PLC in the communications page. I call mine PLC1; then in my tags area right click>Insert New>Variable>Flag. Point the mapping to your PLC and then set it up as below.
File Type: png Screen Shot 2016-01-14 at 8.24.08 am.png (22.6 KB, 32 views)
File Type: png Screen Shot 2016-01-14 at 8.24.22 am.png (14.2 KB, 26 views)
Old January 18th, 2016, 02:44 AM   #11
calamwill
England
calamwill's Avatar
Quote:
that way isn't available on mine for some reason.
__________________
Old January 18th, 2016, 06:50 PM   #12
ASF
Australia
ASF is offline
I just realised that my example was from Crimson 2, not Crimson 3...can't see why that would have changed, but no matter. Did you get it working at least?
Old January 19th, 2016, 01:45 AM   #13
calamwill
England
calamwill's Avatar
nope, it's not working yet. i am not sure whether i have done something wrong or not either because i have no idea what i'm doing haha
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Reading Micrologix 1400 data log records ScottW LIVE PLC Questions And Answers 0 November 2nd, 2015 02:51 PM
Red Lion G306A HMI - PAXI0130 Meter Kravz LIVE PLC Questions And Answers 1 May 6th, 2015 11:02 AM
Red Lion Data Station Plus Question Jmoreno111 LIVE PLC Questions And Answers 1 April 6th, 2015 10:55 PM
HOW TO: Create a Web-Based HMI (Siemens/RedLion) haganwalker LIVE PLC Questions And Answers 9 August 6th, 2013 09:05 AM
Micrologix 1400 to Red Lion G304K cable pinout krakenfan69 LIVE PLC Questions And Answers 12 April 9th, 2012 08:38 PM
