Schneider Magelis HMI - sending a email - email settings
Riaan_bloem
May 2016
bloemfontein
Hi there.
Need some help with this please. I have a HMI, its connected to the interweb as Mr Clarkson will call it. I have a input that will trigger a email, that part works.
However, the gmail or other email accounts has some issue that blocks the email.
I have set my google account for the less secure apps. Tried Port 24/25/465/587 and smtp.gmail.com as well as smtp.office365.com.
Any suggestions will be welcomed.
tx
Hi there.
tx
I have same issue with my SCADA that use Gmail to send from PC. It have block because they detect that I use different IP location from usual. To fix it you need to use your HMI network to create new Gmail account for send by HMI
Gmail uses TLS encryption so this has to be enabled also. If your device does not have that feature then you will not be able to Gmail with authentication!
I have an M241 connected in Ethernet to a HMIS5T panel and I can't get them to communicate I'm using Machine Expert 1.2 On the controller the...
1,792
I've seen a few old threads on here that say there is no way to upload from one of these HMIs unless the developer took the step of downloading...
2,643
Hi everyone I'm having issue with schneider electric HMI vijeo designer. When I update the xvm file and Download the HMI, the communication b/w...
1,210
Hello, I am making a simple temperature measurement so I can configure my PLC and HMI together. I want the value measured by the sensor connected...
3,676
Hi Guys, I do have a problem with a HMI panel. The old one is broken, and i cannotr seem to get the progeam running on the new HMI Panel. We...
4,343
