Lovell
I have been trying to setup a connection between a 1769-L33ER and a WAGO 750-881. The WAGO PLC is part of vendor equipment. I set up a Generic Ethernet Device with the correct IP, INT data type, input 110 - size 4, output 111, size 4, config 1, size 0.
Always errors on invalid size. I tried SINT type as well. Has anyone done this successfully? If so what were your Generic Ethernet Device settings?
Thanks,
Thanks,
