How to copy data in a tag to another tag in Controllogix
cdmeieril
Mar 2007
ST. LOUIS, MO
How do you copy the contents of a dint256 tag to another dint256 tag in Controllogix while offline? I've done it online with a copy statement.
Thanks,
Cory
I am assuming you mean an array of DINT with 256 elements?
If the data in the source tag already exists example x_256[256]:
Go to the Tag Edit screen, and right click the array, then select copy.
Go to the new tag (bottom of the list), right click and select paste. The new tag will be created based on the name of the original one appended with a "1". It will contain the same values as the original. Then you can rename it as desired. Edit: You may have to blow away the existing tag first...then rename the new one to replace it...
Another method would be to use RS Emulate 5000 and do it with the virtual PLC COP instruction.
Hope this helps,
Paul
Copy tag from your master project to a new blank test project. Do a COP instruction to your new tag. Run test project In RSLogix5000 Emulate. Copy Tag back to your master project. Data table values will be retained in new tag
I just loaded the Emulate program and will try that. The way we usually do it is with a copy statement when connected to a processor. I don't have that ability right now.
Thanks for your help.
Cory
This feels like a simple, elementary question, but I am a Siemens novice and know there are experts here. My S7-1500 project (TIA Portal v17) has...
2,706
Hi everyone! I am working on a Siemens plc (1200/1500), and I have two instruction that i have to perform. A) data structure (40 bools, 40...
2,455
Hello! I am completely new to PLCs, so I apologize in advance if this is a dumb question. I have a device that sends out its data as a number of...
2,137
Hello, I am new to Siemens' Simotion Scout software. I looked for a thread that might include this but...I have a CU320 and an existing project...
2,639
In a few months I'll be decommissioning a PLC-3. We have a DOS VM with the AB6200 software that can apparently go online with this beast. I say...
1,459
