Allen Bradley Panel View Plus 700 Touch Screen HMI
Vipin
Oct 2008
Dubai
I'm Facing a problem with touch screen panel( Make Allen Bradley- Panel
View Plus 700)
While startup it shows a error message cannot run more than one program at a time and loading continues.
The panel screen lights up with initial menu.
Further Levels of Menu cannot be accessed since the Touch Screen is not functional.
Only physical symptom is screen is slightly warm compared to before.
Any one please help
Regards
Vipin
FT Configuration
Sir,
Many thanks for your response.
I'm quiet new to this Allen Bradley Thing.
It came as a part of BRADMANLAKE Cartoner machine used in food industry.
Once You switch on the machine the screen will display the programme loading sequence,in between You can see a error message of more than one programme cannot be run.
Machine will continue loading software and end at the initial screen of Bradman Lake Cartoner.
From that point You cannot access the further programmes because of the dead or non responsive touch screen panel.
As per one of the Engineer the panel should be replaced since it is not responding it may be dead.
But i don't accept that fact since at least one error message has been displayed and how can I expect a touch screen panel to go dead while on operation.
At the PlC end it shows run signal and a COMM LED in continuing blinking mode.
Please feel free to ask for further clarifications
Regards
Vipin
You might have to toss it. These screens do some weird things. For instance, I have a PV+ 600 that displayed a "stuck touch" error. So, yesterday I replaced it. I took it all apart to get the screen off, then powered it up and... "stuck touch" still appears.
It's now in the trash can.
Before tossing it I'd probably plug in a USB mouse and keyboard and see if I can poke around and get something up other than the application. On bootup, when the little square appears in the bottom right hand corner, try pressing F1 on the keyboard. That may get you into the config menu.
Do you have FT View ME software? You could create a very simple application that has a "config menu" button on a display. Compile, download it, and tell the PV that you want to run the new application when it reboots. (The original app will not be copied over unless you make the new app the exact same name.) At least then you may be able to access some system features.
on my Allen Bradley HMI i want to put a login and logout screen for when my operators want to reject a part in production i want to eliminate this...
1,500
Hello everyone, im new in Allen Bradley World, i alredy know how to use factory talk view and with manager i have alredy upload all runtime...
1,695
Here at My work we purchased a system from an Automation vendor a year or so ago and the Allen Bradley PLC and Panel View Plus give control to...
4,321
Hi all, I've been asked to edit a Panel View C400 but i'm unable to communicate with it. The screen was installed by A.N.Other and I tried using...
4,494
Hi gents, In my allen bradley panel view plus 1000 HMI have three levels of password protection, ( OPERATOR, MASTER and ADMIN). I would like to...
3,183
