the Master goes to Stop Mode and the second slave still in RUN Mode
shaker Hosain
Mar 2010
USA
31
Hello :
please could you help me?:
I have PROFIBUS Mono System Network(One Master(CPU313C-2Dp) & Tow Slave's(CPU313C-2Dp))when any Slave go out from the service ,the Master goes to Stop Mode and the second slave still in RUN Mode.
but I want to keep the Master in RUN Mode too.
What can I do?
Hint: Look in the diagnostic buffer why the CPU goes to stop mode.
Spoiler: It is probably OB86 that is needed. Typically you add OB82, OB85, OB86 and OB122 to avoid the CPU to go to stop mode due to hardware errors.
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
42
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
228
I have to start out by saying I am not a PLC programmer and I have basic programming skills but mainly use software as a troubleshooting tool. I...
120
Does anyone have an example project of the cm ptp ET200 SP HA with 410-5H DCS (PCs7 9.1 SP1) for MODBUS MASTER/SLAVE communication ?
121
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
104
