can i use SOPDT system parameter idetification in position control with a servo motor
Dec 2009
16 EL-masah ST
74
hi guys
i saw a good topics here in the forum talking about advanced control thanks to peter and pandiani many thanks to them for their time and effort
i have a question which is arising quite often, i'am trying to learn how to construt mathimatical models and simulating especially when dealing PID tuning parameter ,in the past , i was neglecting the effect of the dead time variation and made it constant ,but after that i knew dead time may kill the porcess
my questin is how to tune a position controller with a servo motor using SOPDT
by the way i try euler method for numirical solution for my SOPDT and the results is bad
No, position control is a type 1 or integrating system whereas temperature control is not.
However, if you differentiate the positions so you are doing the identification on velocities or type 0 system then you may get away with it. Usually SOPDT are slower temperature systems and a motor has much faster time constants.
Attached is a zip file that contains a python script that calculates the PID gains for SOPDT systems. You must install python3, numpy, scipy and...
2,654
I plan to do a gotomeeting webinar on SOPDT temperature tuning. This isn't going to be about how Rockwell or Siemens PIDs are configured. This...
42
8,775
Hello, I have no training in maintaining potable water systems, so forgive me if some of my terminology is far off the mark or if I'm focusing on...
74
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
89
Hi all, This is going to be a long post apologies. I'm also a complete beginner to the world of PLCs. I'm currently working on my first ever...
428
